I hand hold almost all my field shots at these focal lengths, but typically at 1/2000-sec and higher. For testing and making declarative statements, I think that a tripod is required to get repeatable, meaningful results. The pixel difference may cause some deterioration, but I doubt that it's near so large
Reply with quotewith these lenses and teleconverters.
For those photographing dollar bills handheld with long teles + 2xTC, fine, I guess...
I used a tripod, in case I wasn't clear.
I meant more that the results at short distances and longer ones are often different.
I long ago gave up testing longer lenses indoors, in order to get meaningful results (unless macro or close-up/portrait is the intended main use of said lenses).
That is what I have said a few times but dcstep seems disagreed. For such long lenses, really the result is only meaningful if you shoot from distance, ideally at least 50x of FL. So for a 600mm FL lens, you need to shoot at least 30m away, basically reflect your usage in real world. Ideally setup a tripod outdoor to shoot on a big building/architecture from a distance.
I personally don't believe testing on a currency bill is that meaningful as they all appear sharp (because of aliasing) that also related to on how you align tripod properly.
For the same reason I don't take DPR or IR or TDP studio tests too seriously as they all taken from close distance. DPR real-world scene from the roof of the their Seattle HQ is much more meaningful and revealing in my opinion.
I think that we only disagree to the extent that I think that both types of tests are valid. A lenses that's sharp at 15-ft is not going to suddenly be soft at 30m, unless there's an AF problem (not the case with the a9). The only potential misleading aspect of the 15-ft currency bill technique is that it tends to show performance in the middle of the lens and not test the corners; however, for bird photographers we don't tend to be too concerned out at those corners, because we're cropping them off 99% of the time. The standard lenshood on the EF 600mm f/4L IS III vignettes seriously, for example, but no one seems to care.
I was shooting egrets and small mammals yesterday and paid attention to my shooting distance. The keepers were within 10m and still cropped:
So, I think that my tests are valid, but so are yours, just different.
