It has been a while now, and little or some updates there, and i keep going.
I wanted to have high end scopes, but my life getting worse and i feel i am cursed, but i will pray sooner or later that things will get better and not have bad things again so i won't give up.
1. I bought SW 180mm F15 Mak as starter for planetary or solar system, i didn't want to have 8" or 11" SCT as i said before then i replace it and wasting more money, so i bought this Mak because it can give closer FL needed for planets to those large SCT, so i can always practice with it until i am ready for larger heavier scopes [14" i hope].
2. I bought non Astrodon NB filters in 36mm, so now my filter set is complete [LRGB + NB].
3. I am looking for to buy second scope regardless i didn't use or take out that Mak out of the box, but the other scope is completely different goal i want to use, which is deeper DSO, and this scope is definitely a Newotonian, but i don't know if i should go with 10" F4 or 8" F5, i want 1000mm FL specifically, not 1200mm, not 700-800mm not even 1500mm, so i have to choose one of those 2 for that FL.
My mount damaged before i can test my new filters of NB or my Mak, i sent it to one computer store who has technicians keen for motherboards or electrics boards so maybe they can fix it before i buy another replacement board, it damaged by power shock accidentally, i was careless i think, and it happened so next time i won't do same mistake and i talked about this problem enough, so this problem isn't a topic here.
I also will start to do guiding, i setup my camera and guide scope but couldn't give it a try, in fact the mount fried in that night so i stopped, i wanted to test guiding and NB for the first time but happened what i didn't want, and i hope all my equipment now will be matched to do astrophotography as good as it should be, and later will see what i can do more.
Now if i buy one of those 2 Newt scopes above, i will buy the cheap one, but then i will replace things later such as the focuser, maybe another mirror or keep same mirror if it is good, and definitely will buy a good coma corrector which i already know what one, but then i don't know which collimator i should get, there are many between cheap and little pricey, so don't know what the difference between them.
Any suggestions here will be appreciated and welcome, learning is a matter of time and effort, i bought books, so even if i buy so many equipment it won't stop me for learning easy or difficult, i watched videos and did read posts to know that nothing is impossible if someone really give/put all his best and time to make it working, i did read someone said "I can't collimate that 10"/12" F4 no mater what, it is impossible" while i saw so so amazing mind blowing images from this 10" F4 Newt, so either this person is giving up quickly or he never give time to do it precisely, or others are using magic and miracles to make it working, this kind of things that many members told me to start cheap or simple to learn, but this way is good if i have enough budget later or in the future, so i buy once for long term, and that is why i didn't buy a refractor because it sound i will just wait longer and buy something high end [TEC/Tak/AP] and never look back, i was slightly to buy a Skywatcher Esprit 100mm which is a great nice scope or similar, but some who have those scopes upgraded undoubtedly to something else such as FSQ-106 or APM... so it means one day i will upgrade too and it means i will waste more, i can't sell, so i will get things slightly, some for one time, and some as replacement but not same type just for practice such as a Mak, and i still didn't use any of my Canon lenses in AP yet, so i feel only a good Refractor is missing which i can wait longer to have one of top quality or high end, and i was thinking to start with something like 70mm or 800 wide, but i remember that Takahashi has reducers so i can turn one of their mid scopes to wide and never look back, so it will be like i bought 2 scopes, they even have extender if i want longer one day.
Thanks again.
