R
RealWorldPhoto
Guest
Do we really need dark frames with today's system cameras (DSLR and mirrorless), due to the very low noise with CMOS sensors?
For those who are not used with the term "dark frames", this is exposures without light, taken with the same duration and at the same temperature as the image files, used to reduce noise. The filtering process is done with astro software.
Years ago I used cooled CCD-cameras, and every astro session included dark frames and flat frames. I also added bias frames when processing the files. For CCD sensors, using dark frames made sense.
Now I have scaled down my astrophotography to system cameras with CMOS sensors (I like to call them cosmos sensors) and small telescopes, up to about 350 mm focal length. I also use small unguided trackers to keep everything as simple as possible.
I keep the camera sensors clean, so flat field frames are not needed to remove dust spots. I skip these too, and correct for vignetting at post processing. No specialized astro software is used, just Photoshop, except for Registar for stacking files.
This works fine for my small scale astrophotography, since the end result is just for pleasure and not intended for any kind of scientific studies.
So: Do dark frames make a visible difference when using system cameras?
This photo showing the Faming star nebula and surroundings in Auriga, should tell something about what level of astrophotography I am doing with a standard system camera, a small refractor and a not guided star tracker.
