No.Am I correct in assuming, that a 20D, due to it's 1.6x crop factor,
actually uses "less" of the lens' glass...
You meant less of an image's image circle above. Every pixel looks at the scene through the entire lens aperture.and therefore does not
"see" deteriorating edge IQ?
And that's enough, and all that's claimed.yes, ok, but...2.56x advantage = 1 1/3 stop advantage.Yeap, I think Neil has the same understanding as me. Just that he
is better at explaining himself than me. I still struggle to
understand how a FF body has 2.56 stop advantage over an
equilvalent 1.6x cropped camera.
yes, overall it gets more light - but that's only because it's biggerBecause the sensor is 2.56x larger and at the same f-stop, it's
getting the same light per unit area. 2.56x the area, times the
same light per unit area = 2.56x more light.
F-stop controls the light intensity at the sensor. Exposure calculations always include ISO.as i said before, how can a smaller sensor get more intense
light, which would equate to a difference in exposure
Right.imagine you have a white card. shine a torch at it. if the torch
covers the whole card, then the the whole card has (for arguments
sake) 1unit of light power at every point
now cut the card in half
the card is now 50% in size, and the torch hasn't changed
the card is still receiving 1unit of light power at every point,
but there is also 'wasted' light where the card area has been cut
away
Correct.the light is not more intense
And more total light will be captured.the only way the light can be more intense is if there is some kind
of modifier that focuses all the light that was on the 100% card
onto the card when it is half the size
therefore a card half the size would receive 2units of light power
at every point
surely just because the sensor is bigger doesn't mean the image
will be brighter. it just means that more of the image will be
seen (i.e. no "crop factor" on focal length)
Nothing to do with the pixels.personally i suspect it has something to do with the pixels being
larger, which makes them better 'capturers' of light. however are
the pixels proportionately the same size compared to the sensor on
each camera?
The claim is not that either the focal length or the f-stop actually change when you change bodies.e.g. on a piece of card 100cm square the pixels are 1cm square
on a 50cm square piece of card are they 0.5cm square?
because if the pixels are larger, they are able to capture more
light - therefore it has nothing to do with sensor size per se,
just pixel size
although this is just a whim - i may be wrong
Let's keep this argument separate for now. Jury is still out. I for one think and observed that 1D3 does not have less noise it's just masked better.Is this a test? : )Please read to the end before you answer.
Now, since the intensity of the light on the sensor is the same,
it will meter the same, but since the total amount of light is
more, the noise will be less.Eugene, obviously, I am talking about sensors of the same designNot true. 1Ds has the same light gathering capability as 5D and
1Ds2 and more than 30D, 400D yet it has more noise than any of
these cameras.
and generation. I mean, the new 1DIII has less noise than the 5D
sensor as well. It's a new generation of sensor.
Likewise, FF has even more than a 1 1/3 stop noise advantage
compared to Nikon sensors, and more than a 2 stop advantage
compared to Olympus sensors. That's a whole other argument.
True but it is also true for FF camera not just crop camera. If you stop down any camera you need to decrease shutter speed or increase ISO.Thus, you must up the ISO by a factor of 2.56 to get the
same exposure (or, alternatively, reduce the shutter speed by a
factor of 1.6, or some equivalent comination of ISO and shutter
speed).Not "not true". : ) If you shoot f / 2.8, ISO 100 on 1.6x and INot true. There is a small sensor inside the camera that determines
the exposure in the camera not the size of the main sensor. Your
statement above contradicts your answer to me about the gray card.
shoot f / 4.5, ISO 250 on FF, we will get the same shutter speed
and exposure.
--So, for example, if I take a pic with a 1.6x camera at 100mm, f /
2.8, 1/100, ISO 100, I will get an equivalent image with a FF
camera taken of the same scene from the same location at 160mm, f /
4.5, 1/100, ISO 250. The two pics will have the same FOV, same
DOF, same exposure, and same noise.Again, you must up the ISO 1 1/3 stops as well. Then the shutterTrue, but you also changed f/stop. I think I know at this point
what you are trying to say you just need to rewrite your statement
above. To include that 2 things need to be changed not just one.
For example putting camera in program mode and changing F stop from
2.8 to 4.5 will give different shutter speed but DOF will be the
same as on the 1.6x crop camera.
speeds will be the same.
Now, if the total number of pixels is the same , then the noise
will be the same on a per-pixel basis as well. However, FF sensors
have more pixels, thus the per-pixel noise is higher, but the
total image noise is the same. So, the FF sensor gives a more
noisy, but more detailed, picture.Again, I just thought that was kind of obvious that I was talkingNot true. It depends on the camera.
about sensors of the same design and generation.
--joe
http://www.josephjamesphotography.com
http://www.pbase.com/joemama/
Please feel free to criticize, make suggestions, and edit my
photos. If you wish to use any of my photos for any purpose other
than editing in these forums, please ask.
Less of an image circle does use less of the glass despite looking through the entire aperture. If that's not true, please explain.No.Am I correct in assuming, that a 20D, due to it's 1.6x crop factor,
You meant less of an image's image circle above. Every pixel looksand therefore does not
Flemming, regardless of what recent threads have said about crop vs full frame, and regardless of whether the exact terms you are using are correct per Lee, there are a couple things that should be clarified. First, lens performance often tends to suffer in multiple respects with further distance from the center of the lens. Hence all MTF curves show performance relative to this distance. Second, when utilizing full frame lenses on crop bodies, most professional reviewers note that the crop lenses enjoy a "sweet spot" effect by not using the parts of the lens which are most distant from the center. Lee and Joe are challenging these widely held notions, and have provided some limited evidence for their point of view, but by no means have either of them proven that full frame IQ does not suffer on the edges more often than crop. The reverse has also not been proven, but it is a more widely held belief.Am I correct in assuming, that a 20D, due to it's 1.6x crop factor,
actually uses "less" of the lens' glass and therefore does not
Flemming
With pleasure. I actually don't have any evidence about the noise performance of the Canon sensors vs other brands or the new 1DIII sensor.Let's keep this argument separate for now. Jury is still out. I for
masked better.
and exposure.
In fact, I did explain it further up in this thread:True but it is also true for FF camera not just crop camera. If you
ISO.
Your mistake is that you did not explain that you are only trying
to match DOF between the two cameras. Once that is understood
everything falls in to place. It is pretty basic.
I also said it in this post (in this thread) as well:To get an equivalent image, we up the f-ratio by a factor of 1.6
(1 1/3 stops) to get the same aperture, anc consequently, same
DOF, and same total light. However, that light is spread over 2.56
times as much area, so the intensity of that light is 2.56 times less.
Thus, you must up the ISO by a factor of 2.56 to get the same
exposure (or, alternatively, reduce the shutter speed by a factor of
1.6, or some equivalent comination of ISO and shutter speed).
I have to disagree here. If you are trying to match DOF between the two cameras you are correct but if not these two lenses don't behave the same. At F4.5 regardless of the focal length you will get little less than twice the amount of light regardless of the camera.The claim is simple. An example is, a 50mm f2.8 lens on a 1.6 crop
camera will behave the same as an 80mm f4.5 lens would on a
full-frame camera. These are both hypothetical lenses and we're
equating their performance in terms of image quality (noise),
depth-of-field, diffraction, and exposure. Now, exposure includes
ISO, and the larger sensor camera will need to run at a higher ISO,
say, 1000 on full-frame versus 400 on 1.6 crop.
Again, only if you are trying to match DOF otherwise not true.It's no accident that a 50mm f2.8 lens and an 80mm f4.5 lens have
the same physical aperture (50/2.8 = 80/4.5 = 18mm). Since they
have the same angle of view on their respective cameras, and since
they have the same physical aperture, they are providing their
respective sensors with the same image. The larger sensor's image
is larger, and therefore the light is more spread out (less
"intense") but the final result is still a match in terms of noise,
DOF, and diffraction, and you get the same shutter speed with each
system.
And so is FF 80mm F4.5 1/120 ISO 2000 and FF 80mm F6.3 1/60 ISO 2000 and I can go on and on.So, 1.6 crop, 50mm, f2.8, 1/60th, ISO 400 = full-frame, 80mm, f4.5,
1/60th ISO 1000.
Lee Jay
(see profile for equipment)
I'm not sure where you're disagreeing with Lee. What you and he said is both correct.I have to disagree here. If you are trying to match DOF between the
camera.
Again, I'm unclear on what you are saying. Not just for DOF, but for everything. 50mm, f / 2.8, ISO 100 on 1.6x produces the exact same image as 80mm, f / 4.5, ISO 250 on FF. Same FOV, same exposure, same shutter speed, same DOF, and, for the same output size, the same noise.Yes, for matching DOF only on crop and FF cameras. Otherwise
pointless argument.
The second link I gave you:but it got broken in to so many pieces that people got confused
eventually.
Actually, the whole of the optics are used, but I, myself, am unclear of the specifics, so I'll let Lee Jay answer that.Second, when utilizing full frame lenses on crop bodies,
No one denies that FF does not suffer on the edges, but certainly no more so than cropped cameras do. The evidence is pretty overwhelming:Lee and Joe are challenging these widely held notions, and have
Yes, it is. A lot of widely held beliefs are wrong. A large part of the reason that people have this particular wrong belief is that, while people have gotten accostumed to the idea of multiplying the FL by 1.6 to get an equivalent image on FF, they fail to realize that they must also multiply the f-ratio by 1.6 as well.The reverse has also not been proven, but it is a more widely held belief.
Let's make it clear.The claim is simple. An example is, a 50mm f2.8 lens on a 1.6 crop
say, 1000 on full-frame versus 400 on 1.6 crop.I'm not sure where you're disagreeing with Lee. What you and heI have to disagree here. If you are trying to match DOF between the
camera.
Again, I'm unclear on what you are saying. Not just for DOF, butYes, for matching DOF only on crop and FF cameras. Otherwise
pointless argument.
--joe
Joe, I don't think those data are that overwhelming, and the widely held beliefs I cited are widely expressed by a number of experts, not just yahoos like me. Also, I would not expect a sweet spot effect, if such a thing exists, to be evident when using an EFS lens. Please note that I am not challenging you or Lee, and I am a believer lens equivalence as you define it. I also find that full frame has pretty much made all my lenses better for one reason or another, I am simply pointing out that when you go up against widely held expert opinion, the burden of proof is on you.No one denies that FF does not suffer on the edges, but certainly
overwhelming:
http://forums.dpreview.com/forums/read.asp?forum=1029&message=23296470
http://forums.dpreview.com/forums/read.asp?forum=1029&message=23297008
http://forums.dpreview.com/forums/read.asp?forum=1029&message=23301485
I mean, that's pretty hard core evidence to the contrary.
Perfect. We are on the same sheet! : )Let's make it clear.
Yes, above statement is correct as long as you include DOF. If you
don't include DOF there are many more combinations of shutter
speed/aperture to get the same results.
overwhelming:
Check this out:Joe, I don't think those data are that overwhelming, and the widely
Absolutely correct, except that some cropped glass may cast a considerably larger image circle relative to the sensor than does FF glass. For example, the 60 / 2.8 macro works on the 5D with extension tubes.Also, I would not expect a sweet spot effect, if such a thing exists, to
I completely accept that fact. I no more expect people to merely take my word, than I will take the word of others. That's why I explain the theory, work the math, and post the pics.Please note that I am not challenging you or Lee, and I am a
Not only it is a bad test but total waste of time because he used two totally different lenses.http://forums.dpreview.com/forums/read.asp?forum=1029&message=23296470
--Yes, it is. A lot of widely held beliefs are wrong. A large partThe reverse has also not been proven, but it is a more widely held belief.
well.
Thus, people have been comparing FF edges with cropped edges at the
same f-ratio. That's as silly as using the same FL and then
comparing sharpness. Clearly, if one took a pic of an object at
100mm from the same position with both a FF and 1.6x camera, the
1.6x camera would most certainly have more detail. Likewise, the
edges of a 1.6x camera will be sharper, and it will vignette less
(if using FF glass), if the FF camera uses the same f-ratio.
People need to understand that, just as you use 1.6x the FL on FF
as 1.6x, you also use 1.6x the f-ratio, and 2.56x the ISO. It is
the failure to understand that key point that causes all the
confusion.
That's the mission Lee Jay and I are on.
--joe
--Actually, the whole of the optics are used, but I, myself, amSecond, when utilizing full frame lenses on crop bodies,
No one denies that FF does not suffer on the edges, but certainlyLee and Joe are challenging these widely held notions, and have
overwhelming:
well.
confusion.
--joe
