mostlyboringphotog
- Messages
- 10,475
- Reaction score
- 4,003
Yes - I was amplifying and not disagreeing - I wondered if someone could misconstrue "the total DR of the sensor doesn't change." to mean all the sensors have same DR.I don't think we are saying things that are mutually exclusive. In fact having 14-bit RAW is part of what allows the bigger DR of the bigger sensor to be represented.Yes, the total DR of a given sensor does not change; however R5 has 14bit ADC whereas M1.3 has 12 bit ADC. the difference readily measurable in photonstophoto chart .Again, set the camera to highlight priority and perhaps it will do more to what you are used to. Pentax has this feature also, and Fuji also has it as you set DR 200% and DR 400% - in particular the later will give you insane highlight recovery. Of course the shadows will start to suffer- the total DR of the sensor doesn't change.You’re right, from what I saw, it did seem to pull up more from the shadows. I didn’t necessarily fault it for the highlights, just noticed it handled the highlights differently than other digital cameras. I started to expose LESS to the right than what I had grown accustomed too.Anon has a highlight priority mode (at least several models before that one do so would be surprised if that one doesn’t) the dr total is the same- they shift the dr window for youInteresting. I’ll have to give that a go. Thank you for the tip.Yup, ISO 200 is very conservative and leaves a lot in the highlights for recovery in RAW (more than almost any other brand to my testing). if you shoot ISO 64 and use the histogram, clipped is clipped so you can better manage the DR.Interesting. If I'm understanding you correctly, you are saying that I could push ISO 100 or 64 on the E-M1.3, don't ETTR as much (as I would in ISO 200) and I can pull the shadows up more in post (without noise consequence). Is that right?One final point, dont be afraid of ISO 100 or 64, consider them shadow priority and watch for highlight clipping, especially in your sunset style shots. You will find it easier to manage DR and probably get cleaner shadows.
I did notice that could pull much more back in the highlights with the E-M1.3 than with the R5. From what I saw, the R5 had less tolerance for highlight recovery…surprisingly so.
so don’t be surprised if a camera recovers less highlight but it recovers more shadow - that may still be equal or more DR no would expect the canon to do highlight priority without sacrificing shadows much and still outdo the em1
Perhaps, my second guessing was not needed.
