Steve Dudley
KiltosHi Kiitos,
I looked at your example and downloaded it. It's very small so it's
hard to determine a lot from it. Here are some thoughts.
The image was taken at 1600 which will never be as sharp as lower
ISO. Actually considering it's 1600 and a tight crop, I think the
image is darn nice. Canon's are designed to focus on the highest
contrast item in the focus area you select. In this case, I think
it's the brown where it meets the color of the petal rather than the
center as you'd wanted. Here is a good post explaining it.
http://www.fredmiranda.com/forum/topic2/241524
I'd suggest you take some more pictures with a normal (100-400) ISO
and good shutter speed of a variety of different subjects that have
high contrast. That will determine if your camera is working
correctly in day to day use. If you still have problems, do the test
suggested above.
Also, the 450 is a little soft straight out of the camera when
shooting JPG's. Try changing picture styles or better yet, create a
custom one that has the "pop" you want. It;'s very easy to do. I'd
suggest that you consider doing a little post processing. Faststone
Viewer is free and excellent. You can download from your camera, do
batch conversions and processing etc. If you need to correct white
balance etc. then other software works better but Faststone Viewer
will handle the vast majority of processing quickly, simply and
efficiently.
HTH
Jim
i can show you similar photos of flowers with Af that I have taken exactly the same and I think you really are as Jim said getting good results. DOF is very shallow and Jim has given you some good advice and i think if you follow it you will only improve.
