- Messages
- 30,186
- Solutions
- 112
- Reaction score
- 12,428
morel22 wrote:
Mako2011 wrote:
morel22 wrote:
PasD50 wrote:
do you use a protective filter in front of your lens? make sure to use the lens hood all the time!
morel22 wrote:
Mako2011 wrote:
morel22 wrote:
Mako2011 wrote:
morel22 wrote:
Mako2011 wrote:
morel22 wrote:
evan47 wrote:
actually, with the 18-105, (not sure about the 16-85).the lens hood is a petal type and must be fitted with the larger , (wider) petals positioned top and bottom, the smaller petals left and right. if not you will get corner vignetting at wide angle settings.fact.
i have owned this lens and know it is a fact. others have done it too. it is a bayonet fitting not a threaded fitting. if you have the 18-105 dx nikon and its supplied hood try it. you will find that i am correct.silent tim wrote:
Are you serious? None of my lenses allow you to mount the lens hood in such a way that you can do this, the thread only locks when the lens hood has the petals in the correct orientation."fact."evan47 wrote:
I just checked mine and it only engages if done correctly!silent tim wrote:
My 18-105 must be 'defective' then, because I have just tried it and the bayonet does not engage unless it is on correctly.
Just like my Sigma, Tamron, and Nikon lenses - they all behave the same way and the lens hood will only lock in place in the correct orientation.
Shrug, this is no value to the thread, I'll say no more on the matter, just seemed like a strange observation to make.
I have it and checked it. silent tim is correct. You can force it on wrong but it will not lock as designed unless lined up correctly. If you continue to force it on wrong....the retaining notches may eventually wear and the hood might no longer stay in place as designed.evan47 wrote:
Here's how the 16-85 hood is mounted:evan47 wrote:
actually, with the 18-105, (not sure about the 16-85).the lens hood is a petal type and must be fitted with the larger , (wider) petals positioned top and bottom, the smaller petals left and right. if not you will get corner vignetting at wide angle settings.fact.Mako2011 wrote:
With the manufacture's supplied lens hood....there is no vignetting issue as they by design avoid that.morel22 wrote:
Thanks for the clarification.Mako2011 wrote:
No, he is asking about the lens hood with regard to contrast as having it in place can often increase the contrast and greatly improve image quality in some lighting situations.morel22 wrote:
I don't use UV filters.. And you mean to keep the hood in order to avoid scratches?PasD50 wrote:
My opinions are my own and not those of DPR or its administration. They carry no 'special' value (except to me and Lacie of course)
So does the lens hood pros outdo its cons at all cases?
The con being vignetting as far as I know.
That is my approach as well except for long exposure Noise reduction. Long Exposure Noise reduction only kicks in at exposures longer than 8 seconds and can be very beneficial as a dark exposure is taken and hot pixels (lack of a better term) get mapped out. For other noise I use Topaz DeNoise and find it far more effective than the in camera noise reduction. Other folks here may have better advice than me though....I'm no pro.morel22 wrote:
I definitely learned a couple of new very useful stuff so far.
What about the NR reduction? Does that affect RAW or only addresses JPEGs? I believe setting it off should result in sharper photos and then deal with the noise in PP is definitely a better approach?
How can you tell? Is this something you can see in ViewNX 2 in the metadata? Or is it because you don't see a focus box in NX2 so that means it didn't achieve a focus lock?Mako2011 wrote:
In the first pic focus is locked but the image is still soft. In the last two pics focus never locked. That is because you have your menu a2 set to "release" when you need it set to "focus". While you're there, set menu a3 to "off" and a1 to "release" or "focus". OK to leave a1 set to "focus" for now while you work this out.
The differences you see are because you are using two different lenses and the light is different in each. Light dif resulted in slightly different exposure.Which was exaggerated, shot to shot, because you had ADL set to "Auto"morel22 wrote:
Ok, i'm back to settle this sharpness issue with my D7000..
This time I shot two comparison photos with each of the 16-85 and 35/1.8 to compare how they fair under bright light at ISO 100..
Shot in raw, converted in ViewNX to JPEG at 100% without any touches..
Picture Control set to standard, Noise reduction off, Aperture Mode at F11, matrix metering, single fixed focus point, mounted on a tripod, VR off..
Somehow the camera went with slightly different SS with each lens.. 1/60 with the 16-85 and 1/50 with the 35..
I shot one at 1/60 with the 35 but no difference.. I rather use the ones shot at 1/50 since the other two were shot with a smudge on the lens that I noticed later..
To the photos:
16-85mm, focus point set at the far trees in the backround
35mm, focus point set same place as the above one
16-85, focus point at center
35, focus point at center
Ok, I think the difference is obvious:
The 35mm is significantly sharper and consistent all over the image, and delivers better contrast!
The 16-85 two images look a bit washed out and blurry in comparison!
The other three areas for lenses, vignetting, fringing, and distortion are both out of interest and comparison here as these are two different purpose lenses..
What matters is contrast and sharpness. And the question to be posed, is the 16-85 performance acceptable?
And could there be any issues with the body instead, if there're any??
Lack of focus lock is a known due to the missing focus box in ViewNX2. It can also be seen in data represented in other EXIF viewers. The a2 setting is also shown in other EXIF viewers but not in ViewNX2.tedandtricia wrote:
Sharpness issue is most likely due to mirror slap dif between the two lenses (mirror slap worse at 1/15s-1/80s)...next time just shoot in MUP mode or live view to medicate that. Other differences are just due to different lighting (see the shadows) and minor differences in lens sharpness/contrast. Bottom line....your fine. Don't worry.
scokill wrote:
Hope you don't mind, but they really aren't that bad. I did a quick sharpen (perhaps too much), boosted saturation, and denoised the background. Someone with better PP skills than me could probably make much better. Took 1 min or so.
But I think you've received some good advice.
I'm aware of the possibilities available with PP.. I use LR4 and I develop all of my photos there..
I was amazed though by the image you did! Maybe a little oversharpened but how did you achieve all that sharpness without any artifacts? Specially given that it's a JPEG as well..
Denoising the background is also new to me.. It's not there on LR is it not?
That lens is a good one. Like all lens though...they have sweet spot where they are at their very best. In the case of the 16-85...fair light, f8, and around 1/250s, IMOmorel22 wrote:
I know I should get different results from the two lenses, but just wasn't sure about the 16-85 performance as I thought it should deliver sharper images out of the camera!!
Maybe I was expecting too much from the lens.. Thanks for the confirmation that nothing is wrong with neither the lens nor the body..
I have few remaining questions though if you don't mind:
ADLRegarding ADL I forgot to turn it off.. And that we mention this feature, is it wise to keep it on all the time? And on auto too?
Mirror slap imparts a vibration to the camera and lens. How much that vibration affects the image depends on how that vibration affects the lens/camera combo. A rock steady tripod lets the camera/lens take all the vibration...a longer lens vibrates in larger moments (amplitude) than a short one just as a short pole vibrates in shorter stokes (up and down) than a really long pole. Simple things can mitigate that vibration....a heavy towel laid over the lens can dampen the vibration. Really long or really fast shutter speeds can make the vibration less noticed (at 1/500s the amplitude and frequency of the vibration is not noticeable, for example).About mirror slap, why would it have different effects on different lenses? If it's too much to explain briefly I'd appreciate a link or any article about the issue.. Same thing about the range where the slap is at its worst.. Just out of curiosity..
Not really other than you simply have to plan for it and not really practical using it to photography the family dog running around or needing to take lots of shots real fast. Remember..mirror slap is only a problem on tripod around 1/15s-1/80s (for the most part). Some consumer VR lens element seem to be affected by it in the 1/100s -1/200s range but school still out on that one.And regarding MUP, does it have any disadvantage other than needing to press the shutter button twice?
This oneFinal point is about the Exif! I couldn't find the info concerning A1 and A2, as well as focus lock, and ADL was assigned a value so how to tell it was on Auto.. What Exif reader are you using?
