adobe CS and spyware
Barry
my husband came across this post on the rec.video.desktop
newsgroup-had never come across this before.
post says :
If you've bought Photoshop CS and have noticed a new service
called "Adobe LM Service", this is Macrovision SafeCast spyware.
This spyware cannot be disabled. When the startup type in WinXP
or Windows 2000 is set to "disabled", SafeCast re-enables itself the
next time Photoshop is started.
Just an FYI for anyone considering upgrading. Adobe has finally
fallen over the edge.
responses were:
Not quite a virus, but SafeCast does a lot more than advertised.
Each time Photoshop is started, SafeCast takes an inventory of
the machine it's installed on, and will refuse to load the application
if it decides too much has changed. The copy protection appears
to be analogous to that found in Windows XP:
and
The most frightening part of SafeCast is that the licensing terms
can be changed AFTER THE PRODUCT IS PURCHASED.
So, for example, if Abobe decides to make Photoshop a
pay-per-use application and customers do not agree to these
terms, Adobe can remotely pull the plug on these customer
has anyone heard things like this. First i have come across it. I
haven't upgraded and things like this give me food for thought for
sure.
Greg Anzalone
http://www.greganzalone.com
Copy a generic .txt file in the Adobe system shared/service directory, delete the Adobelmsvc.exe file and rename the .txt file accordingly.
Then open the former .txt file properties and select "read only" and "hidden". Then select the "protection" tab and negate the authorisation to all the listed users (also under the "advanced" button.
Start CS and get back to the above directory. You will find a MS dos link pointing to the dummy file.
Should work.
Ciao
...and make the dummy a system file, read only. But even that
probably won't stick.
-bruce
maybe replace Adobelmsvc.exe with a dummy by the same name?
feivel
Greets from Rome
Mauro
http://www.pbase.com/m_ben/
I see there's more problems being reported with 'activation' in the PC Tools forum. Maybe someone here can help?
David
post says :
responses were:
and
sure.
