Hi,
I have just upgraded from a custom build pc running 4 core intel i7 890, 2.9 Ghz (turbo 3.6ghz), 12gb ram, 1gb graphic card, crucial 256gb ssd, to a refurbished hp workstation z420 running 6 core intel xeon 3.3ghz (turbo 3.9ghz), 8gb ram, 1gb quadro 2000 graphic card, with same crucial 256gb ssd.
My primary intention to upgrade was to get a faster pc for raw file editing. I'm a busy guy at work and get very minimal time at home for raw file editing. Hence the requirement for a faster pc.
My old build would take a few seconds to load all preview when adobe bridge is started. Depending on preview size, it would take like 5-8 seconds to fill my 27 inch screen. After selecting the required images to be loaded to ACR, it take about 4 seconds for the first image to get clear in the edit window. During this 4 seconds time, I can see a yellow triangle with exclamation mark appear to the top right corner. This 4 seconds delay continued for every next image selected.
Now, with the workstation setup, the above mentioned 5-8 seconds has reduced to 1-2 seconds. My 27 inch display gets filled with preview images in 2 seconds max, this was definitely welcoming. But, after loading images into ACR, the above mentioned yellow triangle now appears for about 3 seconds compared to 4 seconds. This is not a big improvement.
Where is the bottle neck? Is it processor, ram, graphic card, ssd or some other component? What can I change to get a max delay of only 1 second, for the image to get clear (yellow triangle to disappear). This can save me a lot of time especially during selection of keepers. My way of doing things is to load all images into ACR and then check each image for focus, those that are out of focus are tagged for deletion. If i have to wait for 3 seconds to check each image, then its going to take me a long time to select the keepers. A delay of 0-1 second is fine since time is not a luxury i have at home for hobby.
Appreciate any solution than can make the yellow triangle disappear quickly.
AJ.
AJ.
