OK, but I'm feeling dense.... HOW do I compare?
You'll need to come up with an objective 'figure of merit' for evaluating your cameras; and pick whichever camera has the best value. I wrote this earlier:
My question was far more specific, but perhaps in that sense also misguided.
Let's say I do a DCP profile in adobe. I then apply the DCP profile to the color checker.
How do I know it worked properly?
Other than "looks OK by eye". Is there a practical, end-user technique that will tell me that, generally speaking, all the software and raw development steps in the middle more or less ended up with the "right" result?
<snip>
I went to the Neutral 6.5 which calls for 160/160/160. I played with exposure and a bit of curve to get it near that (160,164,166).
The I looked up blue (13) which is (56,61,150). What I got was (0,41,191) so I'm clearly on a completely wrong track.
Are you trying to adjust the colors even after you did a calibration? So you don't like the calibrations? First of all, I would make sure that you used good practices when shooting the target: making sure that the target is evenly illuminated, that there is insignificant vignetting, that you aren't over- or under-exposing the image, etc.
That goes to the jist of it -- I'm fairly happy with the results, applied to real world photos.
I probably should stop there, but I didn't.
I also compared the same real world photos with other raw conversion processes. And individually, separately, I'm fairly happy with those results.
My conclusion -- my eye is flexible, and easy to please. A.k.a undiscerning. Compare it to, say, a piano -- I could not tune one, and can barely play, but can definitely tell you when one is off. It kind of "hurts" to listen to. And like photos, piano tuning is not a simple, decided science -- you do not just follow the half ratios in each octave. There's art to it, and like color art I do not understand. 10 pianos could sound quite differently but all be "in tune" and sound ok. Maybe I prefer one to the other, but they do not have that almost "hurt" quality that a really out of tune one does.
Yet lots of people could listen to a very badly out of tune piano and enjoy it equally, and not hear the difference.
Others can see when colors are wrong, and I think they see it better than I. (Note I have been tested and I have no color blindness at all, just like people who might not know a piano is out of tune could test perfectly in all ranges for hearing).
So my question still goes to -- given I do not trust my eyes to be as discerning as I might like, are there techniques I can use to tell if the workflow I use is producing "right" results, so those with more discerning eyes will not go "yuck".
Here maybe what I should be asking is what word goes where I used "right" that can be measured?
Or is there just no practical answer to that -- art remains art (at least within the means of an average hobby photographer)?
<snip>
Using the ColorChecker target for calibration is really rather poor, as there are only a few patches and measuring the target is problematical. A much better method is using a spectrophotometer to measure the entire spectrum of the light source, and using a monochromator to actually measure the spectral response of the camera. You then can develop better profiles for your cameras but then you'll still have problems with inaccuracies, simply because the spectral sensitivity of cameras don't precisely match the sensitivity of the average human eye.
A tool I have works much better for me than a tool I don't.
Seriously -- the answer to my question may be somewhere between "it's not a meaningful question" and "you do not have the wherewithal to answer it". That's OK too.
<snip>
DxO's raw processor has an optional module that attempts to make the colors from one camera match those of a different make. That might be of interest to you.
I'll look, though that has been a very pleasant side effect of these DCP profiles. My D800 and D4 long ago had very different colors run through the same raw process in Adobe. After a DCP profile applied, largely the same (the AWB was also quite different but that's a different conversation). I've been doing it ever since, and colors, especially under jagged spectra lights, tend to be very similar between cameras.
Anyway... thanks for trying to educate the ignorant; I'm trying (in either definition of the usage).
