The source of the problem is that the programmers put no schedule minimum on shutter speed, believing (apparently) that IBIS will handle it. They're depending on the fixed, user-set limit instead. That means every time you change a lens, you need to change the min setting, or shift to S-mode. You already have to do this on Olympus cameras with non-IS telephoto lenses above 150mm, for similar reasons.
The solution for me is to set a lower min speed, probably something like the inverse of my shortest lens (12mm) rather than turn it off entirely. For the test shots, I jacked up ISO by hand. I just object to lazy program designers not thinking about their envelope corners & making me band-aid their laziness. I do take new cameras to the corners to find these things. Better to know now than when the UFO lands right in front of you.
Don't get me started on cameras not having a hyperfocal range setting. Every manual prime lens has it etched on the focus ring. There are manual zooms with an entire family marked. There's a computer in these cameras capable of doing optical transforms, but they can't solve one lousy equation for the user?
