noggin2k1
- Messages
- 3,129
- Solutions
- 4
- Reaction score
- 4,209
Having owned many flash options for the a9III, I just thought I'd share some of my experiences. Nothing too scientific, just my thoughts:
Godox V1S
Works fine if you're planning on keeping things under 1/500s shutter. HSS falls apart when going above 1/500s. TTL is a little underexposed, but easy to correct. No longer own as I've replaced with V100S.
Godox V100S
My workhorse for when working in dark environments., and/or I'm wanting to bounce flash. TTL again is a little underexposed–I generally have it set to +0.7 on the exposure when using direct flash. In dark environments, it gives a very pleasing soft light when using direct flash. HSS does work when above 1/500s shutter, but this obviously kills the power.
Godox iT30Pro
Perfect for those "not too dark dance floors" and I want a lighter setup. It works flawlessly with the 24/2.8G, however it does just show a tiny bit of shadowing from the lens when used with my other dance floor lens (16-25/2.8G) at 25mm, and more prominent at wider focal lengths. Once cropped and straightened, I can just about get away with it between 23-25mm. I haven't tried in daylight or above 1/500s with TTL, as it realistically doesn't have the power. TTL seems more accurate than other Godox models.
Godox X3
I'm not a big OCF user, but a couple of these are in the bag for either direct flash detail shots (iT30Pro or V100S handheld), or the very rare occasion I want OCF without on camera flash. TTL works all good.
Sony HVL-F46RM
Works flawlessly for having flash sync at any shutter speed without HSS, and TTL works perfectly. My 'go to' for direct flash daytime fill flash/portraits. Game changing, and it's a wonderful compact size too. If you want to make the most of flash sync at any shutter speed, this is the flash to have. There are only a few criticisms I have which stop this being my 'only' flash:
Behaves very much the same as the other Sony unit, but a lot bigger with added range (which is of no use to me). Has an attachable diffuser, but it's not going to replace the V100S', so I no longer own these units (much prefer the compact size of the F46RM's).
There we have it. If Sony could make an HVL-F46RM2 that features:
Godox V1S
Godox V100S
Godox iT30Pro
Godox X3
Sony HVL-F46RM
- 4x AA batteries. The flash chews through batteries (even when using Eneloop Pro's), and there is no battery meter–so I'm always replacing between weddings. When you've got a lot of weddings on the bounce, and using 2/3 flashes per wedding, that's a lot of AA's to juggle.
- No attachable diffuser for bouncing flash.
- Sony OCF is a bit crap.
- The light looks a lot 'harsher' than any of the Godox options–they all look more pleasing to me.
- Round head
- Attachable bounce diffuser
- Rechargeable battery with battery indicator
- A decent wireless trigger (not essential)
