peweuk wrote:
1. Why is the clipping only at 25mm. Is that perhaps due to the position of the lens at that setting not being quite far enough forward to clear the edges of the Barrel - but thereafter clearing it - or some other reason. (Similar to the appearance with low zoom when adding a TC to the camera).
2. Why is the clipping not even on all four corners - this would imply that the sensor is not central to the lens/barrel (assuming 1. is correct) - if that is the case, is it a problem that needs addressing?
Troubling, isn't it ? If you read my (edited and addended) bug-report here:
http://www.rawtherapee.com/forum/viewtopic.php?f=3&t=3620&p=25673#p25673
... you can see what I think that the RT 4.x developers ought to do about it.
(As I already posted), I recommend that you download a RW2 or two from the Photography Blog FZ150 revue Image Samples web-page (which I am unable to access), and see if a (3rd) FZ150 has the same non-symmetrical bias towards the right edge. If so, it (may) well be a result of the FZ150 design (and/or a lack of quality control in FZ150 production-testing).
It is, however (to me) unclear whether what can be seen is the result of an actual "vignetting" effect, or (may) also result from actual software code-routines in RT 4.x itself ...
It's funny that neither the FZ50 or the FZ28 (RAW and RW2) image-files, respectively cause this problem (at all, at any Focal length, including full wide-angle). But maybe
not so funny for FZ150 owners ? Panasonic's use of a larger number of extra photo-sites (4144 in the horizontal dimension) may have something to do with this phenomena appearing in the FZ150 (and FZ100?).
The RT 4.x developers may (possibly) "kick it back" to Panasonic (if Panasonic is responsible for the asymmetry). In any event, it seems (to me) that the RT 4.x developers need to work around whatever kinds of manufacturing flaws that Panasonic is "pumping out" - or else RT 4.x will remain unusable for FZ150 RW2 (unless the user specifically has to crop the previewed image-frame in order to achieve acceptable results).
Nevertheless, the 64-bit versions of RT 4.x are here said to not exhibit the same effects. For us folks with 32-bit Win OS only, that may be a disadvantage ...
You're on your own at this point. I'm sure that some luminaries will guide you farther with their deep understanding of the subjects at hand (as well as subjects that exist only within their minds).
DM ...
