michaeladawson
There have been threads here that talk about the wish that Fuji release a monochrome camera. The standard response is pretty much always that it is a niche product and wouldn't sell enough to be profitable.
There seem to be two major advantages of a monochrome camera that get pointed out. 1) There is no interpolation of pixels to arrive at a final image. In a color digital camera the value for each pixel is derived by interpolating it with the other pixels around it. The result is a less accurate image. 2) Because there is no CFA all pixels capture photons from all wavelengths. More photons is better, better in lower light.
Instead of coming out with a true monochrome camera why doesn't Fuji opt for monochrome mode similar to what the Pixii camera does? Pixii engineers know what the absorption values are for the different RGB filters on the CFA. It is a simple matter to calculate what the full spectrum capture of a pixel would have been if there had been no color filter. For example, if the red filter blocks 66.6% of "non-red" wavelengths then you can multiply the captured value of the red CFA pixels by 3 to get the non-filtered value.
I know, I know. You are still calculating a value and therefore what is recorded isn't really the "true and accurate" value. But I have to believe that it would be a really close value that would not really be discernible in the resulting photo. On top of that, B&W film stocks are well known to have spectral responses. So any inaccuracies with the Pixii method could be thought of as its own spectral response curve.
In any event, this would allow for not having to interpolate the pixels to produce a final image. This should result in sharper images. The Pixii method, while not perfectly accurate, seems like it would produce images a cut above standard interpolations. This seems like a good option for B&W mode on a camera without resorting to a monochrome camera.
In fact, this method would not have to be in the camera at all. Since it is a demosaic function it could be provided as an option in any raw image processing software. All that is needed is an accurate CFA table for each supported camera.
