the oly lens must be near perfectNice write up.
There is another dimension to this equivalence thing if we are also concerned with image quality: If the lens needs to project the same image on the smaller APS-C surface it requires a better lens to produce equal image quality.
You're wasting your effort. Mr. Llama doesn't believe in a spherical earth...eh...equivalency.Consider an 8x12 print taken with a full frame camera, using a 100mm lens at f/8, a shutter speed of 1/100, and a subject distance of 10 feet.... Only on this forum have I seen people trying to make the case of equivalent and equivalency.
Would it have been possible to take a photo that looks the same with a crop body?
If the answer is "yes", then it makes sense to ask the question "how would I determine what focal length and settings would be needed?". The next question is "How do I determine which images can be visually matched?"
It manifests itself at all apertures where diffraction isn't completely dominant.That issue manifests mainly at the widest entrance pupils of the fastest lenses; it is more difficult to find f/1.4 lenses, for example, that are sharp wide open.Nice write up.
When one is doing something like macro, though, or anything with specific deep DOF, diffraction is the dominant blur, and equivalence of analog image resolution is achieved.
There is another exception to equivalence here too, for smaller pixels on front-side-illuminated (FSI) sensors; they lose light at low f-numbers, generally somewhere around f/2.8 or so, where larger pixels might not lose until below f/2, but this is about pixel size; not sensor size per se.
Basically, the effect is like as if there were a circular neutral density filter in the entrance pupil that was clear over much of the inner circle but darkened near the opening edges, losing some light, and getting slightly deeper DOF than expected.
The question is one of terminology. what does it mean to say "equal settings"? (in the context of "equal settings" vs. "equal effect") Is it reasonable to say that two cameras, both at a 24° angle of view and a 25mm aperture diameter, are at "equal settings".If we assume that the goal is to view the image from the entire sensor at the same size, and it is about getting the same composition, perspective, DOF, brightness and noise.Even "equal settings" is unclear. The question is what aspects do you want "equal"?Agreed, very weak. "Equal settings" and "Equal effect" might be simpler and clearer.Weak definitions, if even that. That is why your writings draw so much controversy.Sure. In the context of my post, "equal" means the same nominal value on the lens and/or camera whereas the term "equivalent" means the same effect in the photo.Concise definitions of the terms "equal" and "equivalent" would be a good start rather that trying to show the difference by example. Most good technical writing starts with a clear definition of terms before diving first into examples.
Consider a full frame body set to a 24° angle of view with a 25mm aperture diameter.
On a 2X crop body, which of the following would be "the same settings"?
- 24° angle of view and 25mm aperture diameter
- 24° angle of view 12.5mm aperture diameter
- 12° angle of view 25mm aperture diameter
Another way of describing these settings are :
a full frame with a 100mm lens at f/4 compared to a 2X crop body with
- 50mm lens at f/2
- 50mm lens at f/4
- 100mm lens at f/4
We also get into issues of whether the resulting prints should be of "equal size" or "equal magnification" (ratio of print size to sensor size).
In that case the answer would be 50mm at f2. But you need to bring ISO in the picture.
I am curious. I have no interest in weighing in of this oft discussed topic, but how can a thread starter on this forum start a thread related to photography and have it be called "off topic"?You are not a beginner and that post isn't a question.
I'm sorry for the confusion. This thread was originally posted in "Beginners' Questions".I am curious. I have no interest in weighing in of this oft discussed topic, but how can a thread starter on this forum start a thread related to photography and have it be called "off topic"?You are not a beginner and that post isn't a question.
It's his topic, he started it and it is related to photography.
Ah, that helps. I was trying to place the comments.I'm sorry for the confusion. This thread was originally posted in "Beginners' Questions".I am curious. I have no interest in weighing in of this oft discussed topic, but how can a thread starter on this forum start a thread related to photography and have it be called "off topic"?You are not a beginner and that post isn't a question.
When it was moved to "Open Forum", I tried to delete my post but, of course, it was not possible to do so!
Used in that way you must be specify how they are equivalent. Surface area? Field of view? something else?A 16:9 image and a 1:1 can be "equivalent", but never equal.
A OOC image taken with a FF 3:2 camera can be equivalent to an OOC M43 image, but never equal.
Because they have different aspect ratios.
My full frame DSLR (Canon 5D mark IV) allows me to choose from a handful of aspect ratios, 3:2, 4:3, 16:9 and 1:1.A 16:9 image and a 1:1 can be "equivalent", but never equal.
It happens all the time on these forums. Watch what happens in this thread...There was no confusion, just people like you who did not take the effort to read until the third post in the thread...A recent thread has spawned some confusion on the use of the word "equals" with respect to focal length and relative aperture.
https://www.dpreview.com/forums/post/62175139
= means I see the same «window»
Could be better expressed but his logic was correct.
This attitude is not very nice in the beginner forum.
I think you are a good member on dpr, honestly, but my feelings were that this was not very nice.
Yes it does. Moderator ninja edit strikes again!Ah, that helps. I was trying to place the comments.I'm sorry for the confusion. This thread was originally posted in "Beginners' Questions".I am curious. I have no interest in weighing in of this oft discussed topic, but how can a thread starter on this forum start a thread related to photography and have it be called "off topic"?You are not a beginner and that post isn't a question.
In terms of photography, "Equivalence" is used to refer to settings that yield the pictures of the same subject that "look" the same. The common criteria are:equivalence nounequiv·a·lence | \ i-ˈkwiv-lən(t)s, -ˈkwi-və-\
Definition of equivalence
3: to make or produce something equal to
Equivalence as it's related to photography seems to me to be a new use of the term as it relates to cameras with different sized sensors and how it relates to lens focal length.
Excellent summary except, when referring to noise, you must specify sensors of the same or equal technology. Should we add the same sensor resolution?In terms of photography, "Equivalence" is used to refer to settings that yield the pictures of the same subject that "look" the same. The common criteria are:
In other words the settings that give you equal results.
- same field of view
- same perspective
- same depth of field
- same motion blur
- same image noise
This is most often used when comparing cameras with different sensor sizes. For instance:
and
- Full frame, 100mm, f/4, 1/60, ISO 400, 10 foot subject distance
are generally considered "equivalent" as they produce images that look the same according to the above criteria.
- 2X Crop, 50mm, f/2, i/60, ISO 100, 10 foot subject distance
I agree, I should add a note about equivalent sensor technology, or simply leave the noise issue out.Excellent summary except, when referring to noise, you must specify sensors of the same or equal technology. Should we add the same sensor resolution?In terms of photography, "Equivalence" is used to refer to settings that yield the pictures of the same subject that "look" the same. The common criteria are:
- same perspective
- same motion blur
- same image noise
and
