540 slave mode question
D2M-Photos
Active member
US
so i have a big shoot comming up on sunday and my photographer friend loaned me his studio lights with triggers
my question is . i cant get my af540 to flash in slave mode when his nikon sb900 will .
i have it set up correctly i think , cuz when i pop up my flash on my camera it works like its suppose to , but the studio lights ever turned all the way down on power still wont make my 540 pop off and flash .. what am i doing wrong?
doing photography since june 2007
being serious about it since summer 09
Pentax K7 - D-BG4 Battery Grip
DA* 16-50mm F/2.8
DA* 50-135mm F/2.8
Sigma 150-500mm F/5-6.3
Sigma 10mm F/2.8 Fisheye
Sigma 105mm F/2.8 Macro
2 - AF540fgz external flash
Silk U-212 Deluxe Tripod
Benro 98m8 CF monopod
If you're using studio strobes to trigger your 540, make sure you're in Slave Mode 2 (SL2). Hold down the "Light" button for a few seconds until the SL mode shows. I'm assuming it will show SL1. Turn the adjustment dial until your lcd shows SL2. Then, press the "Light" button again. That should do the trick.
If you were in SL1 mode, your 540 is looking for the preflash PTTL signals which your studio strobes won't provide.
Hope this helps. Good luck on your shoot.
Awesome thank you very much
it was set on PH . but i have it on SL2 now .
ill find out saturday when i set up for sundays shoot which works
DA* 16-50mm F/2.8
DA* 50-135mm F/2.8
