I agree, OP sounds like someone who has not properly used existing auto-iso (Nikon) before jumping to the conclusion that it is insufficient. No disrespect intended.
Perhaps the OP hasn't been clear enough, but I think what he asks is entirely reasonable and more than logical :
1) Currently, the fastest way one can modify the minimum shutter speed is by using custom / user modes. This has the following disadvantages :
a) the mode dial frequently isn't placed where you can access it as rapidly as a programmable dial. For example on a lot of bodies it's on the left hand shoulder and isn't exactly the easiest of controls to access while looking through the viewfinder.
Sure, but that is only because it is something you would only rarely change. Like everything else hiding deep in the menu.
There are plenty of things in cameras' menus that I'd like to change much more frequently
b) it wastes valuable custom modes that could be used for broader, less specific setting changes - as an illustration on my EM1, which has four custom modes, three of them are used with nearly identical settings, only the minimum shutter speed being different - if I could quickly adjust the minimum shutter speed otherwise I would be able to coalesce those three custom modes into one, freeing up two extra custom modes.
I dont think "waste" is the right word. custom modes are meant to be used. the fact that changing MSS is something most people dont do often makes it an ideal candidate for the few who wish to use it more often as custom mode.
Well I could already be using the freed custom modes on my Olympus for other uses, so I'd really benefit from coalescing most of these custom modes into one.
c) it limits the user to two, three, even four on an Olympus camera, minimum shutter speeds rapidly accessible.
Sure, but how many do you need really?
As far as I'm concerned I think around four with stabilised systems, three otherwise. But the OP's proposition basically allows you to quickly set the minimum shutter speed at any shutter speed, who wouldn't want that ?
Perhaps Allan Olesen's post would make you realise the usefulness of this : if it's a problem, instead of thinking about it as a minimum shutter speed in auto ISO, think of it as manual mode where the shutter speed automatically goes up when the light level is strong enough to create overexposure. It's conceptually the exact same thing.
If the programmable dial thing is an issue, it's also possible to have quick access to a more limited number of pre-selected minimum shutter speeds with, for example, a lever, or a cycling button. As long as it's faster than the current use of custom modes !
What the op would like is be to be able to set in P or A mode the minimum shutter speed with a programmable dial, thereby solving all the issues above. And if it's a question of not having enough programmable dials, well, for starters I still can't figure out why camera manufacturers still think only two programmable dials make sense on digital cameras - and Sony's proven you can find space for no less than five dials on the right hand side of a tiny mirrorless camera. And I'll remind people that using M mode is different, as what the OP would like is to set the MINIMUM shutter speed, allowing the shutter speed to float upwards if the light is strong enough, thereby not necessitating any input from the user to avoid overexposure. Sometimes, a fixed shutter speed isn't necessary to get the effect one needs, only a minimum shutter speed is.
I just dont buy what you said here. If light level is strong, then shutter speed automatically go up in Av mode to the point where auto-iso-increment doesnt kick in.
And it goes up when ? When the camera's able to satisfy your minimum shutter speed without having to raise ISO. The minimum shutter speed, which you can't adjust as quickly as the shutter speed in S or M mode (or, in many cameras, that you still can't even adjust anyway). That's exactly the gist of the issue.
2) Currently, on Nikon cameras, and all those with a somewhat decent auto ISO implementation, users have to choose between either setting a fixed minimum shutter speed or let the camera automatically set the minimum shutter speed (with an optional user-selectable bias). This means that, if, for example, you're using a 28-300mm, non-stabilised lens and shooting people at an event :
a) You've set the minimum shutter speed to a fixed, 1/60th of a second speed : then everytime you'll go past 60mm or so you'll risk introducing camera shake.
I say, fixed MSS is generally a bad choice when variable MSS based on FL is available.
Amen for that. But in that case (people photography with a 28-300mm lens), it actually is the best of the three options in the 28-60mm (or so) focal length range, since you will prevent the shutter speed going to low at the wide end, or, if you've set a faster bias, the ISO going higher than needed above 28mm. But it's no longer the best above 60mm or so. So, problem.
b) You've set the minimum shutter speed to "auto" with no bias : then everytime you go below 60mm or so there is a risk of introducing excessive motion blur as the camera will select a shutter speed as low as 1/28th of a second at the wide end.
c) You've set the minimum shutter speed to "auto" with a faster bias to avoid the camera using shutter speeds as low as 1/28th without a bias at the widest focal length : then you'll risk to unnecessarily raise ISO at most focal lengths, since the camera will pick, for example, 1/120th at 80mm while 1/80th would have been sufficient.
This situation you are referring to is, by all account rather rare
is it ?
and if it indeed is an issue, I say just use M + auto-iso and everytime you change FL, you make a judgement call as to what is the right SS for that FL to avoid both hand shake and subject motion blur.
Meaning that I would have to frequently change a setting which I wouldn't have had to bother about much if the OP's suggestions were implemented. Not as convenient.
The camera can never be smart enough to work that out for you and whatever it does based on a basic fomular will always be an inferior choice.
The camera's algorithms may indeed not be smarter, but they surely are a lot faster than me - and the whole point of the OP's proposition is to reduce the number of user inputs needed when an algorithm could replace them to some degree. If smarter is needed, well, the OP's first proposition would allow you to quickly correct the camera's algorithm, and of coure there still is manual mode if needs be.
The OP's request is to be able to optionally combine BOTH the fixed, minimum shutter speed, and the "auto" minimum shutter speed. In that case, if you've set the first to 1/60th of a second, the camera will use 1/60th as it's minimum shutter speed between 28 and 60mm, but will use the 1/focal rule above 60mm - eliminating all the issues raised above. It's an entirely logical request.
What you described here may be asking for something that current Auto-iso does not do, but it certainly isnt a realworld shortcoming
I think we've proven above that the current implementation presents a number of shortcoming.
that calls for any urgent fix.
Yep, Nikon has far bigger issues to solve. And a lot of other manufacturers are still in the stone age when it comes to their auto ISO implementation anyway.
