I can't help but feel that there is something off in this combo. I'm sure it is some sort of user error, but for the life of me cannot figure out what it is. This shot is an example when I look at the foliage, the image quality really just doesn't seem to be there. This was shot at ISO 800, f/14, and 1/15. Did I use too small an aperture and am I seeing the result of diffraction? Thanks in advance for any input.
The full image is also here:
This photo has been bothering me for a few days now. Others have pointed out that f/14 will contribute to overall image softness. For scenes like this, my routine uses
hyperfocal distance focusing and very wide-angle lenses. For example, compose your scene at 20mm focal length and f/8, then focus on something 5-6 ft away (which is the hyperfocal distance for 20mm & f/8). Diffraction is not significant at f/8, yet everything from about 3 ft to infinity will be sharp enough (
example).
When I first opened the image, the two things that immediately stood out to me were:
- Very flat lighting
- Colors are too saturated for scrubland or chaparral.
Thanks for including an image with full metadata. In addition to EXIF info, there are many Lightroom post-processing settings included. They show:
- This image was shot in RAW and processed in Lightroom*
- Creative Style "Standard" was set in-camera, the Adobe Color profile was used during RAW processing. For such flat lighting, perhaps the Adobe Landscape profile would have been a better choice. There is probably a camera matching Landscape profile available too.
- Sliders were adjusted in Camera Raw "Lighting" section, perhaps by using the "Auto" button.
- Color saturation was boosted with Vibrance: +15
- Default settings for Sharpening and Color Noise reduction were used. My metadata reader doesn't reveal whether any Luminance Noise reduction was used.
- The camera settings indicate the scene was in deep shade, which explains the flat lighting. The ambient light level was about EV 8.
However, I think the most grievous oversight was using in-camera Auto White Balance or not correcting the WB in post. Using AWB resulted in bluish color cast on the entire scene (see the branches on the log). I'm not sure if you can "process backwards" with a JPEG image, but I tried it in Camera Raw and got an absolutely gorgeous scene with natural-looking color. I also used a little Clarity to boost the contrast. It's a fantastic photo that needs a little processing help.
My suggestion would be to lean into post-processing a bit more and try to avoid Auto or Default settings when possible.
*Unfortunately, Lightroom does not write Sony Maker Notes metadata to the JPEG file. It's not possible to extract non-EXIF camera settings from Lightroom-processed JPEG images.
Lance H
