You should always test a tracker at home first as the usual problems are details which can easily be overlooked. Knowing the handling at night - and in the cold - is extremely helpful.
I've done as much testing as I can indoors, which is to say I've assembled the tracker on a tripod with the camera and balanced the camera on the declanation arm. I've also put batteries in it and let it run for an hour to just see it move the camera. Since the tracker arrived, I've had bad weather, so I haven't been able to go outside and try and align it.
I believe I do know how to focus for stars. I've done it a few times with this camera and lens. It is focus by wire and viewed on an EVF, so test shot and zoom on the screen or on my phone, make adjustment, repeat.
I'm only 40N. Light pollution will be an issue, not auroras sadly and luckily, it is a new moon. Despite all the recent precip, the dew point spread is 20C, the ground is dry and close in temp to the air, (low relative humidity and low to no chance of ground fog). The updated forecast today says tonight's weather won't be here until midnight, if that holds I should have just enough time, if the weather is early I won't see a thing. The forecast for the rest of the week is a mixed bag of overcast skies, fog and a narrow dew point spreads. I'm not sure I will be able to see it 10 days from now when it is forecast to be dry and clear again.
I've got a heavy jacket and gloves, good for extended period outside down to about -5C. I've had too many opportunities to test this.
