Dak on cam
Just for comparison: here is the same scale with an admittedly subpar full-frame setup (to get at 600mm equivalent, I use a 70-300mm 1:4.5-5.6 lens in front of an old 2× teleextender, necessitating manual focus. At least optical stabilisation still works in that setup, as opposed to front-mounted teleconverters).I don't think that my FZ200 felt limited by optics, rather by its sensor performance, not entirely surprising at its size.
Here is a sample shot from a minute ago (raw processed, so less noise reduction than what the internal processor would use):
The script is in focus. The camera picked ISO200 (this camera should really just be shot at ISO100 if you can help it). Rendition is reasonable except for noise. The camera picked F3.5 (but it isn't really much worse at F2.8), a brighter aperture than the HS30EXR can deliver at the long end. That leads to a fairly narrow depth of field, making material out of the focus plane dissolve rather fast, even though the "end blurriness" is not all that large due to the small sensor. Maybe it is that which threw you off? Small depth of field without great background blur to show for it?
That teleextender doesn't fix the EXIF, so we are effectively talking about 600mm at F11 here. The main difference at article size is stronger bokeh (F11 on full-frame vs F3.5 on crop factor 5.6, about F20 equivalent).
When going in, one gets higher resolution, lower noise in spite of higher ISO, and quite more graceful dissolution of out-of-focus regions.
But the setup is much more expensive and cumbersome (in practice, I don't really use teleextenders).
Dak
