That may be true for yourself. I was responding to the OP. Not clear that they understand how aperture affects DOF in the most basic ways, so I don't think they are ready for DOF tables or calculations.Calculating DoF is easy, and the principles are easily absorbed. I don't recall ever being in any doubt about the optimum focus distance.If you're serious about landscape, then in my view, you need to simplify things as much as possible for yourself. Don't look to the camera to do things for you. Cameras are very bad at choosing where to focus in landscapes. For portraits, most people want to focus on an eye, so cameras can do that quite well, now that they recognize eyes. Not so for landscapes. So first of all, you need to learn to choose at what distance to set focus. Then you need a method of setting focus to that distance. You also need to know more about depth of field, how aperture affects this, and have an idea of your depth of field in different situations.
Not sure that's true, but even if it is, it doesn't change the fact that in some scenes, where there is no subject matter at the optimum focus distance, the only way to focus at that distance is via manual focus. Makers could implement a system of setting focus between two AF-derived distances, but I'm not aware of any current implementations of that.Most modern cameras aren't suited to manual focus.As you start to get a feel for the above, all you need from your camera is a way of setting focus at the distance you want it. If there is something in the scene at the distance you want to set focus, you can use AF. If there isn't, you may be better using manual focus (the optimum focus distance in your first image isn't on the trees or on the landscape - it's somewhere between the two).
I've set up several Sony cameras for landscape shooting. They work in much the same way as any other brand. The principles here are largely brand-agnostic.Sony AF is best left to those with experience of the brand.
