Medical Supplies.
I’ve shown this set here before but here it is again.
The set is based on the white background being a priority, so I lit that first.
I also considered the spread of the light. How many lights do I need to ‘cover’ the shooting area. In this case the answer is one. In other cases, it’s more. Full length portraits, for instance, considering that a set might be 6 feet tall, I’ll often use one light for the lower half and one for the face.
Flexibility: The size and density of the diffusion material is easily adjustable. The fill and second light sources can easily be added, in this case a silver card.
This is also a good jewelry set, ideally, a thin wooden frame can be used, topped with non-glare glass. Colors can be added at the back, it comes up a nice pastel and there’s a slight reflection of the subject in the foreground.
I used a tungsten Omni light for it’s spotting capabilities and the barndoors. I could have rotated the plexiglass box for a wider white background but I was happy from the first shot. Total time, setup to processing, six items, was about four hours.
I hope you like it!
Thanks,
J.
composite
Behind the scenes.
Raw file.
I hope you like it!
Thanks,
J.
composite
Behind the scenes.
Raw file.
