I currently have a pretty old Olympus OM-D E-M5 Mk II with the extra grip attachment to make it more comfortable when using larger lenses (so it's more like the OM-D E-M1 line in size, just without all the features). That camera body is no longer up to snuff anymore; in a few months it'll be a decade since it was released. The autofocus tracking is bad, the low light performance is bad, and I honestly think I can mostly take better photos with my Pixel 7 Pro, so I hardly ever use it anymore. I would like a camera that I'll actually use!
The thing is, I have some lovely Olympus lenses that are truly a joy to use, and are fully compatible with the latest body, the OM System OM-1 Mk II. My most used lenses are the M. Zuiko 12-40mm f/2.8, M. Zuiko 40-150mm f/2.8 w/ 1.5X teleconverter, and M. Zuiko 70mm f/1.8. I also have the Panasonic 20mm f/1.7 pancake lens, but the autofocus performance on that is disappointing and I'd likely swap it out for an M. Zuiko 17mm f/1.8, if I'm going to stay on Micro Four Thirds anyway.
So the most obvious choice is to grab the OM System OM-1 Mk II (and hopefully there's some good Black Friday deals). It's maximally compatible with all of my lenses, it's better at everything in every way vs my existing camera body, and it has good reviews. But I could also go for the Panasonic G7 or G9 II, which are better at video than the OM System, but maybe slightly worse at photographs. I do care about video, but I care about photography more, and generally can't be arsed to buy all the software required for video editing and spend all the time making it look good and splicing it together. A wrinkle here is that a Panasonic body wouldn't be as compatible with my lenses; in particular they don't have in-lens stabilization that works well with the Panasonic, so all other things being equal I'm leaning towards the OM-1 Mk II solely because of my existing lens collection.
But then another option would be to simply sell my lenses and start over, probably with a Sony a7 IV. I'd end up spending a lot more money in total going that route though because the kind of quality lenses I'd want for it would cost MUCH more than the M43 equivalents, plus all the gear in total would take up a lot more space and weigh a lot more. I'm generally just throwing a camera plus an extra lens or two into my existing backpack when I travel rather than bringing a lot of photography-specific gear, which is one of the main reasons I selected M43 in the first place; I don't think I'd be able to physically fit a full-frame setup without requiring larger/more bags. But the resultant photos would obviously be better, especially in low light.
So, that's where my thoughts are currently at. Does the OM-1 Mk II make sense? Has anyone else faced this struggle before? I'm specifically asking this question in the general gear rec forum rather than the M43-specific forum because I'm looking for neutral opinions.
