I think this lens came out in 2009 and predates firmware. Nothing on the Sigma site now anyway.
The lens has firmware, but unlike current Sigma lenses it required a trip to their service center to be upgraded.
Common sense tells me that a 50mm which has a wider field of view than the 50mm 1.8g and a 77mm front end is going to let in more light than the 1.8g.
Both should have the same field of view give or take a "fudge factor." Nikon 50mm lenses for example, were traditionally 51.6mm to conform to the Leica "standard."
A 77mm front end will let in more light, but once it passes the iris the amount of light transmitted to sensor is measured by T-stops. While the t-stop varies for different lenses at the same f-stop, it's normally not a huge difference.
I was bored, so here are three shots taken on my back deck. The setup was identical for all three shots using a tripod, so all I did was swap lenses and focus with Live View. Manual mode, f/2.8, ISO 400, sunlight light balance, each used with its OEM lens hood. These are OOC JPGs, so I apologize if the EXIF is munged. NEFs on request.
Tokina 90mm f/2.5 Macro -- This lens has a 55mm filter size. The EXIF shows 86mm because Nikon doesn't let you set 90mm.
Nikon 85mm f/2.8D PC -- This lens accepts 77mm filters, but the front element is recessed. The EXIF shows f/3 because Nikon shows effective aperture with its Micro lenses.
Sigma 85mm f/1.4 EX DG
As you can see, the focal lengths are slightly different. The Tokina
may have produced slightly stronger whites, but nothing "pops" out at me as unacceptable or anything I would worry about.
Light travels at 2.13085531 × 10^14 smoots per fortnight. Catch some today!
