My Nikkor 200-500 f/5.6 has served me very will along with my Z9. However, it recently has developed electrical connection issues (proved it is the lens and not the camera as I recreated the issue on my Z6 and D500), so I have decided to upgrade to the Z 180-600 f/5.6-6.3.
All reviews suggested this lens was at least as sharp or sharper than my 200-500 and focused better. However, with the first few days of testing this lens in the hide in my garden, I have found the focusing, whilst quicker, is a lot less accurate. For example, if I am taking a series of images of a static bird about 3-4m away from me, I will achieve some sharp images, but I will also achieve a lot (nearly 50%) of images which are not quite nailed on (see below - image sequence of great tits - yes I know they are a little underexposed but it is the first example I came across when sorting my photos). With my 200-500 lens my hit rate on similar (and sometimes the exact same) subjects will achieve a hit rate of around 90%. In the 10% of cases it will be clear in the viewfinder that the focus point jumped to the tail or branch - however, with the 180-600 the green square will stay securely on the eye throughout the sequence implying that the focus should be tracking correctly.
Z9 with 180-600 @600mm 100%ish crop 1/1250s ISO 1000 unedited f/6.3
next image in sequence - Z9 with 180-600 100%ish crop 1/1250s ISO 1000 unedited - this bird was sitting totally still f/6.3
To be clear these are some facts that I know people will ask:
Z9 180-600 @600mm - cropped to 100%ish 1/1000s ISO 1000 f/6.3 unedited
Nikon Z9 with 200-500 lens - this long tailed tit was very jittery flying about a lot in a bush with lots of branches and a busy background - I took about 200 photos of it and I had approximately 180 in focus shots which I could use, I just sorted through them for the picture with the best pose/light
Has anyone else experienced these issues (specifically looking to hear from people who have upgraded from the 200-500). I have seen a few other threads with people having focus/sharpness issues to which the response is usually, "you cant expect a zoom lens to be as sharp as a prime" - Im not expecting this, I'm expecting it to at least match the performance of my 200-500 (which almost every review has suggested it will - and usually says it will outperform it). Currently it is quite significantly below - I would not trust this lens to go on an important shoot.
Do you think I have a problem with my lens? I bought it from Wex Photo Video and they are sending for a replacement so I will let you know my experience when they get the new one in.
In the mean time...
has anyone else had this issue?
did I win the lens lottery with my 200-500 (bear in mind I can't stick with it as any slight movements will cause the lens to disconnect and have a F-- error show - it can only really be used on a tripod)?
Are the reviewers wrong, did they just not test the AF in real world scenarios?
- All shots were taken on a tripod with gimbal head
- I have used identical AF settings between lenses. I have also tested both lenses at 500mm f6.3 to make it a fair test.
- Bird AF is switched ON
- I have tried Full AF Area, Custom Wide AF Area and 3D Tracking - the results were the same.
- I have tried both 'erratic' and 'steady' for subject tracking motion
- I have tried the lens at f6.3, f7.1 and f8 - I found the issue happening at all of them.
- I have tried VR OFF, Normal and Sport mode
- The issue still occurs at higher shutter speed in better light.
- Note - I use pretty much the same AF settings as Steve from Backcountry Gallery use.
In the mean time...
