Marco Nero
I've seen some reasonably good images from this lens so I'm not concerned with it's results. Some reviewers were happy with it and it's clearly going to be popular for the additional zoom on the far end, especially for well lit wildlife photography during daylight hours.
Duade Paton (see embedded video below via YouTube) has been working with the new and upcoming Canon RF 200-800 mm F6.3-9 IS USM Lens and has a recent video up showing he has experienced a not-so-insignificant number of super-soft images from this lens that he described as "completely unusable" when doing his review for the lens. You can see some of his examples here. This guy is an experienced photographer who specializes in birding and he's familiar with most equipment out there. The video he posted also shows some Live View footage of the AF struggling to remain locked on the subjects repeatedly.
He mentions that another photographer, who is a friend, appeared to experience the same issue at another time and place. I would agree that heat shimmer could affect some images but not quite with the same consistency we're seeing in the examples he posted as these are very soft and appear to be out of focus. Images on his video show an out of focus subject where nearby insects appear to be in focus... suggesting it's not atmospheric distortion ruining shots.
I suggested that the failure to focus properly is not necessarily connected with "heat haze" but was more likely related to the unusually long focal length of the 200-800mm lens combined with narrow aperture, resulting in a significant change in contrast to the scene. This is something Canon has previously addressed with their EF and RF Extenders by adding a tiny microprocessor that literally slows the AF down to increase exposure and AF accuracy from the lens. The 2x Extenders are programmed to slow down AF by 75% and the 1.4x Extenders slow the lens down by around 50%. This is by design and its to allow more accuracy with the AF. Canon were well aware of contrast with certain apertures and focal lengths combining to hamper AF.
When combined with an APS-C sensor (like that of the R7), it would appear this lens is perhaps punching above its weight and paying the price in certain lighting conditions, depending on the distance to the subject. Of course, it's still good value for money if it can deliver. Thermal Fluctuations and Heat Haze can indeed be a problem when using long lenses on subjects a long way away. I've experienced this myself and yet I find the heat shimmer is very consistent in each frame and you can see this shimmer when playing back images or video. I think it's a good assumption that heat haze might affect AF but that it's more likely that the combined focal length on the R7 is producing contrast at that time and place that produces problems that Canon have observed in the past when coupling extenders with certain lenses. It's also why Canon expressly don't recommend stacking Extenders because they claim that contrast is then impacted to the point where even the optical coatings don't produce enough contrast for the AF to be reliable.
To the birders and long-lens users out there, how much of a problem has heat shimmer presented to you? I've dealt with it under certain conditions with distant subjects when using long lenses, especially with APS-C and especially with Extenders. It's normally not a problem and never seems to present itself as an issue with a FF sensor (for me at least). But I'm presently of the opinion that in this instance it may come down to the lens design (aperture range coupled with focal length and high ISO) combined with APS-C sensors at times of the day when contrast is lower. The Eye Detect AF on the R-series cameras is particularly effective and is generally quite reliable on all models. But I feel that the use of this lens on an APS-C (giving around 1200mm) will push the boundaries of reliability if everyone is shooting at 800mm with an APS-C camera.
Duade is assuming the problem is Heat Shimmer but he leaves room for speculation or for people to suggest an alternative explanation. I'm not entirely convinced it's related to Thermal issues but I'm sure it could influence the results. I've seen other examples by birding photographers shooting close to the ground over rocks in the hot sunlight where they had no problems at all with this lens (see samples by OrmsTV). Reviewer Hugh Sweeny has also observed unacceptably soft images from this lens yet I thought they were close enough to being sharp in most of his examples. Though the contrast was higher when the shots were crisper. Anyone have any thoughts on the subject?
Marco Nero.
