With the newer Sony bodies like a7r5 and a7cii Sony is claiming that oss and ibis can work in co-ordination.
https://support.d-imaging.sony.co.j...body and the,than would otherwise be possible.
has anyone tested this by comparing two lens of the same focal length, one with OSs and one without and see if OSs improves the already excellent ibis? Only a few OSs lens are supported like the 70-200mm gmii and 24-105mm.
I did a test with 85mm prime and 70-200mm gmii on my a7r5 and I can’t really see any improvement using the OSs lens. @85mm I can hit 1/4 secs where the hit rate starts to fall to like 50% or worse and using the OSs lens don’t help at all or is so minor that I need to use 1/8 sec on both lens to get decent hit rate, free standing. Bracing helps to allow me to hit 1/4 on both lens but I don’t see a difference between the two either.
my pics
my pics
