MasterWayne
Forum Enthusiast
OMG.. Just tested it out:I have the control ring for aperture, the front dial for exposure compensation, and keep 99% of the time the fv dial for speed. So I’m working 99% of the time in Av with auto iso. When I need a fixed speed, I just turn the wheel. When I need a fixed iso, I press on screen that’s faster for me.This is the answer I was hoping to get!You can set all 4 parameters independently using the wheels/dials you already have. Just need to configure the camera to be able to do that.Let me give you my reasoning why I am not jumping up and down because of it (maybe the outcome is that I have a wrong understanding, which would be awesome).Conceptually, I think that a good way to look at it is that Fv is Av, Tv, M and P all in one.
Think of it as starting in manual mode. You manually control all three exposure parameters, shutter, aperture, and ISO. You can, at will, set any one or more of those parameters to Auto. Set the shutter to Auto and you're in Av mode. Set the aperture to auto and you're in Tv mode. Set them both to auto and you're in P mode. And in all cases you can quickly and easily change ISO and/or set that to auto as well.
I don't see why people aren't jumping up and down and yelling about Fv. It's like a fundamental reimagining of exposure modes. There's no longer any need for Av, Tv, M, or P, since they are all contained within Fv.
I don't remember what the default is, but I have the down arrow on the D-Pad set to change the currently selected parameter to Auto on both my R series cameras. They also rarely leave Fv mode.
When getting my R5 as my first canon mirrorless, I immediately tried out Fv, anticipating I would love it. Turns out, Fv always uses just 2 wheels. One to change which setting is under current control, one to change the value of that setting.
I don't get it. Including the lens, my camera has 4 wheels. So it finally gives me the chance to control all 4 exposure settings independently from each other. How awesome would be a Fv mode, that would still let me utilize all 4 wheels?! THEN I would jump up and down.
But instead, I would first need to scroll with one wheel to the setting of interest and then use the other to change the value. As I basically did with my 10 years old entry level 100D.
Just writing this now drives me crazy again..
Well, so here's why it doesn't work for me. I tried it. Tried to love it. Unfortunately didn't make it.
I love the Fv mode.
—C
But unfortunately I have no idea how to setup the camera as you have mentioned.
I checked all settings in the custom menu. I can only configure the wheels for the M mode. When I switch to Fv, it would ignore the configuration. Instead, the top wheel changes the currently selected value and the mode wheel let's me change which setting is selected currently. The wheel on the back side shows no function.
The lens Ring indeed let's me change ISO, as configured in the custom menu. But that's just 1 direct control out of 4..
with Sony I used Av most of the time because i had configured to a button the Av minimum shutter speed and kr was quick, but that’s now possible wirh Canon and that’s why I use Fv.
what I don’t understand is why Fv doesn’t follow the rule for auto iso minimum shutter speed, they should implement that in software instead of having the automatic parameter dependant on the focal length.
The front/back dial can indeed be used to independently change exposure comp while being in Fv. It cannot be be used to change the shutter speed while being in Fv.
That's why it didn't work for me, I have shutter speed assigned to that wheel.
This is so dumb and unintuitive.
So I need to assign specific settings to the additional wheels, then I can more or less get my 4 wheel Fv..
I'll give it another try, even if it would mean to reassign all my wheels..
Thanks for your reply and pointing me to this conclusion!
