Hello,
After some years of less intensive photography I decided to get rid off all my Nikon D-SLR's and lenses and got myself a Z9 with some new glass (Standard F/2.8 zooms and a 105 F/1.2).
However I am having a few issues with the camera so far:
Thanks a lot in advance.
- One of my test shots is usually one with closed aperture to check for any sensor problems or dust. It does show some dust I cannot remove by using the built-in sensor cleaning option. Now, it is not to the extend I would normally manually clean my sensor but I am a bit afraid it is "stucked" and can't be cleaned. Now I can go ahead an try to clean it with Eclipse but has anyone ever experienced that dust could not be removed from their Z9 (or even other Z camera)?
- It seems that the monitor does not sit fully flush when "recessed" fully onto the body so to say. On the right upper side there is a bit of play and when I touch the screen (it is a touch screen after all) it "ticks" a bit because I push the monitor against the body. Is that considered normal?
- Even with the menu option for high-frequency flicker reduction set to on I have severe banding issues at home with my Philips Hue lightning. I know electronic shutters are more sensitive but Is this normal, anyway to solve this?
