I just returned from a bird photographing trip and have some thoughts of my 800/6,3 pf + Z9. I was photographing small birds at a hide and seabirds both from a hide and a boat ( BIF) and my thoughts are concerning the autofocus. I use AF-Area wide mode with the AF-On button, 3D-tracking with the Fn 1 and single point with the FN 2 button. The lens works perfect with my AF-ON autofocus for BIF and birds at medium distance ( >7-8m). My problem is birds at short distance , near 5m. I found it very difficult to nail the focus. I mostly use the AF-Area wide mode for getting the first contact with the subject, and I have good experience with this mode at longer distance. My 800/6,3 pf had big problems at short distances. I took my 500/5,6+1,4 E and this combo worked much better, at short distances 3-5m. I also noticed that in order to "nail" the bird in focus , the single point AF got the best results ( birds at the feeding station). As I really like both the AF-Area wide mode ( BIF , snappy focusing of all subjects at medium distance) and the 3D-tracking ( birds or animals moving around in the frame), I have assigned the single point AF to the FN2 button though I find it very difficult to locate it with my fingers. So my questions are:
1) Whats your experience with the 800/6,3pf at close distance and what AF-mode are you using for nailing the subject?
No problem at all really. I don't generally have any problem with nailing extremly accurate eye AF at very close range. Not sure why you would be having any issue with this as I find the Z9 with 800 PF (or other lenses) focusses extremely quickly, very accurately and competently on all sorts of birds at close range.
I normally have the shutter button set to Auto-area on half press as my default AF mode and for birds at close range that usually works without recourse to any other AF mode(s) .. although there are circumstances (eg birds partially obscured in a bush or a tree etc) where I will if necessary resort to switching via FN button to another mode such as custom "wide-area" set as a single point etc. For BIF I usually rely on the default "auto-area" AF mode to initially acquire focus and then I will switch (via FN1) to 3D tracking mode if the bird isn't too far away, or if there is a difficult environment with much to potentially confuse the AF system then I sometimes resort to one of the "wide area" modes (via FN button press). Occasionally if one of those situations arise (rarely since the firmware upgrades) where the AF seems to get obsessed with the wrong target such as the background I can use the FN2 button, which I have setup for dynamic medium (see my settings below) which, with no subject detection allows fall-back to a simple AF mode which can allow rapid reset of AF position.
Here are a few examples:
The first 4 are different versions of the same shot (which was one of many from the same location at the time, and as far as i can remember the camera and lens nailed the all), this one was at range about 6.3 metres, 1600th second at f/7.1:
Willow TIt - downsized version of the full shot, Z9 with 800mm PF
Willow Tit - a cropped and resized version of the above
The same Willow Tit shot as showing in the NX Studio editor showing focus point, fil info data etc
Willow Tit - same shot as above, a tight crop to show detail at 1:1
I don't see any issue with the focus accuracy. DOF can be an issue with very close range which is why I stopped down a little here. Perhaps even F8 would have been a bit better.
Another example, this one at a range of about 7.5 metres:
Blackbird (female), Z9 with 800mm PF, cropped and downsized version
A full size crop to show detail at 1:1
2) How have you assigned your buttons especially for birdphotograhing for different situations (BIF, close birds, birds at medium distance)?
At the moment these are my main working settings:
Shutter button: Auto-area
AF-ON button: Wide-area (C1)
[custom (extra large)]
FN1: AF-area mode + AF ON 3D Tracking
FN2: Recall shooting functions (hold) : AF-area mode dynamic Medium, AF subject detection options OFF, Focus Tracking with lock-on ON
FN3: AF-area mode + AF-ON - Wide-area AF (S)
Sub-selector centre: AF-area mode + AF-ON: Wide-area AF (C2)
[custom single point]
FN4: Metering
Video record button: Choose Image Area
... but I may change some of these in future!
I rarely need anything much different in button settings for most bird photography.
I didn't mention but of course all the above assumes use of "animal" subject detection with eye AF switched ON.
Also, another potentially very important point, I usually use this lens with VR set to "Sport" mode (has to be done via the Z9 menu system as there is no switch for this on the lens). Normal VR mode gives stronger VR but I find that use of Sport mode avoids any issues with focus-point positioning representation accuracy in the viewfinder (such that can occur with "Normal" VR mode).
Frank
