What are the Pros and Cons of the various Shutter Options?
Can you tell me the benefits of each and why you would select a particular setting?
- Mechanical Shutter
- EFCS
- Silent Shutter
- Is there any other?
I am a very old dog but still trying to learn about the modern technology? Your comments will be greatly valued and appreciated.
Depend on what camera you use in my experience.
With stack-sensor as in A1, A9-series, I use e-shutter exclusively including in landscape. The penalty in DR is very minimum and not really can tell difference in real world. A1's e-shutter works flawless to me in all scenarios.
I learned lesson from my A7r IV. I used to use e-shutter lots in daylight that usually ran fine in single shot if don't move much. However I was frustrated in some blurry photos when I did hand-held pano as even shutter speed is around 1/100 that is not that low with 16-35 GM or CV 21. Turned out it's fault of rolling shutter when I rotating camera one shot after another shot that a few (even just one or two) in series are blurry that ruined entire series. I since changed to m-shutter exclusively and effectively addressed the issue. On tripod-mode that assigned to dial '1', it uses m-shutter, uncompressed RAW, IBIS off...
My A7 IV is between that has less rolling shutter but still having that issue if I moving camera a bit too fast after taking a shot before another shot.
When I use m-shutter sure with EFCS as used to with Canon DSLRs. I just cannot quite trust e-shutter on non-stacked sensors in A7/A7r series.
