gary stepic
My home studio obsession is getting out of control Now I am thinking a rail system could help me make the best use out of my small space. This is the space I have to work with -
I saw this rail system from B&H -
https://www.bhphotovideo.com/c/product/250246-REG/Delta_40630_Scissor_Light_Mover_System.html
That particular system would not work because I was thinking of putting the fixed rail along the wood beams and I only have 11', so I would need a smaller 10' fixed rail. The beams are 4' apart. I am now searching for places where I can buy 2 fixed 10' rails and two 10' sliding rails along with three scissor lifts. One sliding rail would run parallel to the bookcases and the other slider rail would be opposite the bookcase wall. I could use one light stand where my scrawny Christmas tree is and if I need a fill light I could use a scissor lift on the sliding rail opposite the bookcase wall. This would eliminate me having to move the couch, which would normally be in the way of a light stand on the other side of the door (the couch has two electric motors for reclining - so heavy and not easy to move, but doable). The sliding rail parallel to the bookcases would have two scissor lifts, for either hair lights or background lights. the sliding rails would move away or toward the bookcase wall and the same for the opposite wall. Scissor lifts might be overkill for using Godox strobes, but they would be way more convenient than space taking light stands.
There is 11' between the bookcase wall and opposite wall. I have about 9' of space for a background on the bookcase wall. I am going to buy two hooks to put on the ceiling beams for a background holding bar, eliminating the need for background stands. Clearly, I have to move the table and small chair out of the way. I can stand farther away from the subject by using the door which leads to my kitchen, so full length shots may be doable. The window, by the way, faces east and there is rarely direct sunlight coming in.
Other ideas would be to use a wall or ceiling mounting boom for a hair light as suggested by Ed. I am starting to like the rail idea if I can get individual components at a reasonable cost. I am not sure if the fixed rail not being parallel to the floor will be a problem. Crap, my studio budget is starting to explode!
Any suggestions on where to buy or put together a small rail system appreciated. Hope everyone has a great Christmas and thank you so much to all for the help you have been giving me - Gary
http://www.honoringcreation.com
