Question on the AF on my R10
Karen Casebeer
Leading Member
I'm new to the R system so it may be a lack of knowledge, but I'm concerned about the AF on my R10. I have it set to spot AF. But when I'm out shooting, the camera has a mind of its own, often switching to other AF boxes, sometimes a whole grid of them. I hope it's me and not a defective camera.
Do you have subject tracking on? In tracking mode, the AF will continuously look for the type of subject you select. Give the AF section of advanced user manual a good read if you are new to this system.
Maybe you’re inadvertently pressing one off the rear buttons with your thumb while gripping the camera. Sorry but that’s all I can think of right now. I set up one of the buttons on the pad of an M50 and experienced a similar issue until the penny dropped.
Just one small addition to PicPocket's answer. Select subject to detect "none", and subject tracking "off". Then, it will behave like M6 mark II spot autofocus. Otherwise, it will try to find a subject near the spot autofocus point.
Spot autofocus +subject detection is useful when you have multiple subjects on the screen and you would like to select a particular one. You can also use the joystick to switch between subjects, or even their eyes.
I don't know if the R10 is like other R-series cameras but are you in One Shot focusing mode? One Shot allows you to pick a single focusing spot and sticks with it. Servo will start at the spot you pick but will illuminate other spots as well searching for best focus.
I'm not a fan of spot AF in most cases. If you want to use this model, use a large spot. It seems like it lets you tell the camera to focus on a very precise spot, but the individual detector needs to detect horizontal or vertical contrast only. If it does not land on an area of contrast, like a line, it cannot focus and your results will not be good.
Thank you! I did have subject tracking on. I think that was the problem but will know more when I go out to shoot tonight.
Hmmmm. I am in Servo because my subjects are moving. Do you think that’s what I’m experiencing? I always have shot in Servo with my m6ii. Will it be different on the r10?
Interesting information. I’ve always used the small spot and placed it on the eye of my subject. Will try the larger spot when I shoot tonight.
Thank you! I hate manuals but can see there’s much to learn on these R cameras with a whole menu tab devoted to AF!
I don't know the R10 or the M6. Your manuals should tell you how each of those cameras work. All I do know is that with my R5 & R6 if I want to track a subject, I set the camera to Servo and let the camera track it for me. I don't bother with spot AF any more unless I am in One Shot and want to focus on a specific area. My camera's subject tracking is far superior than any tracking I used to be able to do on my DSLRs, so I let the camera decide... and I just watch the dancing squares dance.
Thank you! I will try this.
Check out this video - OK its the R5 but similar principles on the R10.
I use the shutter half pressed for traditional single point manual select autofocus - e.g. wherever I put the spot - and thumb on the AF-On for when I want eye-tracking - on both the R5 and R10. (R5 does have extra buttons).
I have programmed the AF-ON button to enable the eye tracking AF - and if it gets it right great - but as soon as it moves off or the scenario you outline release the button and go back to old school SLR type AF.
Start at about 11mins 55s.
Yes, thank you… testing these things for yourself is always always best.
I agree with MarshallG on this. I think people got hung up on Spot AF early on with the release of the R5 because some pro photographers who used it were able to keep the AF on a birds eye when it was in flight so they just transferred that to mirrorless camera system in the their videos. I could never do that. I'm sure others here can.
Spot focus covers a smaller area thus you get less contrast to work with and AF is all about contrast. Canon recommends not to use Spot AF on moving subjects. You will not get sharper images when shooting on a "flat plane" using Spot Focus compared to single point, expansion or zone AF. Spot AF is a specialized mode. If you are shooting the curvature of an eyeball it is a great tool. I have used it when shooting a perched bird through dense leaves and single point AF is picking up the leaves instead of the bird.
This paragraph is from a well respected Canon technical advisor. Link is below.
“Precise” is not the same as “accurate!”
We’ve said several times in this article that the Spot AF option does let you focus on a smaller area of your subject. In doing so, it does allow you to place focus with more care and precision — at least in some instances — than standard, Single-point AF would. But it’s vital for Canon EOS users to understand that Spot AF is not inherently more “accurate” than normal Single-point AF would be. If you set up a test, photographing a flat chart or wall with a tripod-mounted camera shooting squarely into it, you’d get equivalent results in terms of focus “accuracy” in test shots taken with Spot AF vs. the larger Single-point AF. So if you simply switch to Spot AF for all your shooting and expect that you’ll get a higher percentage of sharp images, you’re going to be disappointed.
https://web.archive.org/web/2018032...m/resources/articles/2014/spot_AF.shtml#page2
That being said sometimes Spot can be useful for normal shooting like if your subject is far away and the face is small. The outer areas of Single Point is wider than the face it could pick up foliage, etc behind the subject.
Use Spot if it works for you but don't exclude Single Point or other modes which provides more contrast for initial AF and tracking. You will figure out what works best for you.
Moving on only using Single Point or Spot is really defeating what mirrorless systems are about. Now that you are confident your camera works properly (from your other thread) you may one day want to explore what it can do for you.
The whole thing is all about the eye. These systems are relatively new and are just complex algorithms (AI) trying to figure out what you want to do. As they keep training the systems in then years we won't be having these conversations.
It takes a bit of getting used to withe the new Subject tracking and Eye AF. It doesn't always find your subject and can be frustrating. The key to it is when it can't focus on your subject you help it by using Single, Spot, Expansion or Zone AF as a pre focus technique.
I'm back to old school and use the shutter button for shooting. My camera is set to subject tracking and eye focus. Make sure you are on animals for animals, etc. That makes a big difference. The AF-On is set to Zone AF (for birds in flight) and the * button is set to Single point AF for static objects. There are many ways to program the camera.
Example. If I'm shooting a perched bird and the camera cannot AF I press the * button and any anywhere on the body will do. Once the bird is in focus I go back to the shutter and the eye or face snaps in. Watch this video between minutes 2 and 6. it is a Canon vs Sony shootout but see how the author uses expansion AF to pre-focus on his subjects when the camera isn't doing what he wants.
So as your learning curve gets less steep you may want to try that out. Being able to track your subjects eye is pretty wonderful.
FP
Does the R10 offer the white pre-focus square that that starts to look for an eye as soon as the camera wakes up like the R5, etc? I checked the specs and couldn't find it.
For your information Karen. This is not the pre-focus technique that I talk about in my other post. That technique was created by users. The white pre-focus square is part of the cameras programming options, if available on the R10. It is very handy.
Thank you for this wonderful information, Zeee. I've printed it out so I can get some of the details, but I will try the bigger spot for now and see what I get as a result. I appreciate your putting this together.
You know, I'm not sure. Will look into this more.
Take your time and enjoy your gear. It takes time to digest everything. When you are ready try some new things out if you feel like it.
I shot for years using the AF-on as the primary but with the new systems I went back to the shutter button. Using the white pre-focus square even if I lift my finger off half pressed it kicks in and continues to focus. Many years ago when I used the shutter button I never struggled to keep the button half pressed between bursts.
All types of great programming options for everyone’s taste.
