Wide rectilinear lenses can also create distortions of subjects that are far away but are located near the left or right edge of the frame.
I have to respectfully disagree. I am about 90% sure that is a myth. At least in the age of digital cameras with lens correction. (Back in the days of shooting on film it was probably a thing.)
It's a subtle effect with most wide angles but is more pronounced with ultrawides, especially in the corners where the stretching effect is the strongest. Look at this image of a hotel room, for example:
All the straight lines look straight, but look at the lower right corner:
That does
not look natural. You can imagine what a face would look like in that position.
I think your photo examples help to prove my point
When shooting STRAIGHT ON things are proportional if they are at the same distance from the sensor plane.
In your photo and crop, things are obviously at different differences from the focal plane. The table in the lower right is SIGNIFICANTLY closer to the sensor plane than the wall with the closet.
And also note how CLOSE to the sensor plane that table is. Because it is so close, perspective distortion is exaggerated because the relative distance between the near items on the table and the far items on the table is rather large when you compared it to overall distance from the sensor plane to that table.
Meaning, imagine you are instead shooting STRAIGHT on to a wall about 10 feet away with a wide angle lens. Move that same size table so it is up against the wall. Keep it in the corner of the frame, but move it further away. It will look "normal" because the difference in distance relative to the plane of the sensor is smaller.
If the front of the table is 8 feet away from the sensor plane, and the back of the table is 10 feet away, there is a 25% difference in distance to the sensor between the front and back of the table.
Now, move that table so it is closer to the camera. Put it in the center of the frame. But move it so it is much closer to the camera. The perspective distortion will return because the relative distance to the sensor between the front and back of the table is more significant.
If the front of the table is two-feet away, and the back of the able is four feet away from the sensor plane, then the back of the table is TWICE as far away from the plane of the sensor as the front of the table. Much higher than the 25% difference when the front of the table is 8 feet away from the sensor and the back of the table is 10 feet away.
Again, my belief is that since wide angle lenses ALLOW the photographer to get closer, perspective distortion is enhanced, whether the item is in the middle of the frame, on the edges of the frame, or in the corners of the frame. As long as the lens has been "corrected" for things like barrel distortion and such either in camera or by applying the corresponding lens profile.
Longer focal lengths (typically) don't allow you to get closer. Hence, you are always shooting in situations where there is less of a relative distance between the near and far parts of an object.
What Middle School Is Really Like:
