There has been some discussion about the need for a USB C-PD power source that can supply at least 27 watts of power to both run the camera and charge batteries. I decided to test this out…
Nice!
Still, coming from an electronics engineering/manufacturing background, I'm thinking they had
some reason to put that in the manual.
Incompetent tech writer? Perhaps, but such docs have be reviewed by engineering and marketing several times before they are released to production.
Yes, but coming from a person who does the review side of manuals, some times things get missed when going over these large manuals. Particularly for a manual that starts with the previous generation manual, and then is modified over time. Sometimes things stick in the manual long after they should have been removed. And note, these manuals are written in Japanese and then translated to the English that I read.
I tend to think it may be several things.
The previous generation (E-m1 mark III and E-m1x) that was the first generation to use USB C-PD for powering the camera, though neither camera would charge the batteries while powering the camera. Both of these cameras evidently would not run at all with USB C-PD unless the C-PD power source advertised it could provide at least 27 watts of power.
Thus when they created the OM-1 manual from the E-m1 mark III manual, I suspect this line was copied. The power rating in the E-m1 mark III manual (27 Watts or 9V/3A, 15V/2A, or 15V/3A) is the same as the OM-1 manual.
Note, 2 restrictions in the E-m1 mark III manual (you can't use PD if you connect an HDMI device and you can't use PD if you attach the HLD grip) were removed in the OM-1. It is curious that the line in the E-m1 mark III manual that you need at least 10% power in the BLH-1 battery to use PD was removed, but the OM-1 still seems to have the same limit, just the documentation was removed.
Perhaps 27 watts (i.e 9 volts and 3 amps) is the theoretical maximum power that the camera needs. Doing the measurement with 4K video and 60fps, I tried to use the most amount of power, but I don't have an OIS lens or HLD-10 grip that could draw more power. I speculated that perhaps it was something like 9 watts for the camera itself, and 9 watts for charging each battery. But my tests last night suggest that the camera will only charge the battery with any left over power that isn't used for the current operation.
Over in the mu-43.com forum where I posted the same numbers, AussiePhil mentioned that the camera specifically asks for 9 volts and 2 amps when connected to a 20 watt USB C-PD system (he/her/they just got meters that specifically monitor which PD/QC connection is used). AussiePhil also said with their/his/her tests, the camera might go up to 9 volts and 1.2 amps with an OIS lens, but her/his/their HLD-10 grip doesn't work right now.
The SBCX-1 charger will not do fast charging of the BLX-1 batteries unless the PD source claims it can provide at least 27 watts. My tests show that the SBCX-1 will only draw 18 watts to charge two batteries, so I don't know why it asks for 27 watts.
Healthy design safety margin? Perhaps, but supplying a 27 watt power supply costs them more than supplying a 20 watt one, and competent companies are very conscious of those costs.
(Aside: I once worked at a place where a fresh-out-of-school engineer proudly substituted a cheaper bypass capacitor, saving the company about 20¢ per unit. Then, they began coming back on warranty, costing the company about $200 each to fix.)
If you assume the manual is wrong to save a few bucks on a power source, you may run into a boundary condition some day where your assumption fails.
Sure, but as I mentioned above, it appears the camera actually requests 18 watts.
