Interceptor121
- Messages
- 12,604
- Solutions
- 8
- Reaction score
- 9,603
The first camera with Quad Bayer sensor was the GH5S however this used it in standard mode and this was back illuminated not stacked as the resolution was only 10.71 megapixels the sensor IMX299CJK offered an HDR mode but not single pixel mode because all the pixels in a cell have the same color
Note that the HDR mode produces a standard resolution image in two exposures
www.gsmarena.com
Which means the latitude that is offered it is typically around 1-1.5 stops from your zero. So the latitude of this HDR shot is similar to your two stacked images at +1.5 -1.5 is not as strong as stacking 3 images a +3 0 -3 for example. Mostly this is used by phones that after all have tiny sensor to produce good landscape photos which are not your typical camera stacked HDR photo.
This in camera HDR mode does not replace your 3 exposure standard HDR shot but is a good option to improve a landscape shot you would not want to have an HDR look. Drones that have quad-bayers use this trick effectively.
The new IMC472-AAJK has also a quad bayer structure however it has two additional modes
Phase difference: this means each pixel can be used for auto focus without having to have specialised pixels. The benefit is cost as now you can have contrast and phase detect on the same chip
Single Pixel: this mode is used by phone to produce a high resolution image however as the bayer filter is still built for the lower resolution this is for most a marketing hype
In conclusion a quad bayer filter does not offer superior dynamic range but it does offer on sensor HDR shot and the possibility to flexibly define autofocus pixels instead of a fixed range
Smartphones have gone through this process and camera are already
At the end sensor size remains the primary driver of dynamic range and even phones have dual pixel AF (Apple iPhone) so there is not much to be gained since 2018 has not taken over the world and neither will happen in 2022 because this technology is used vast scale by OMS
In my opinion Sony cannot continue to run Exmor (front illuminated) Exmor R (back illuminated) and RS (stacked and back illuminated) forever they need to rationalise their factory and Exmor front illuminated is not a line that is releasing anything new since a few years while the other two are very busy with phones, camera, security and industrial automation.
They had most likely a choice between Exmor R and Exmor RS and the RS line with quad bayer with pixels of 1.65 microns in a 3.3 micron cell is very similar to the process used for mobile phones making this cost effective and offering some other benefits in terms of cost. The stacked line also has the benefit of faster readout so this was a no brainer otherwise they would have needed to keep the pixel count low and nobody wants a 10.7 megapixel camera for photos.
Now they can serve the entire MFT market with a single product that is going through the same large volume production of chips for mobile phones. The immediate benefit is apparent more AF points and additional options for HDR in camera with less ghosting but it is not a sudden leap forward in dynamic range or image quality. In video this can also offer 120 fps readout however this requires you to be able to process them downstream which has been historically the issue. This is why there are no 120 fps video modes as the rest of the camera can't digest them easily but another camera with better hardware might be able to
It would be good to have bobn2 in such thread as he was very qualified to address accuracy but he has somehow gone missing I hope he is well
instagram http://instagram.com/interceptor121
My flickr sets http://www.flickr.com/photos/interceptor121/
Youtube channel http://www.youtube.com/interceptor121
Underwater Photo and Video Blog http://interceptor121.com
Deer Photography workshops https://interceptor121.com/2021/09/26/2021-22-deer-photography-workshops-in-woburn/
Quad Bayer sensors: what they are and what they are not
Marketing departments are trying to sell you on the wrong thing - resolution isn't why these sensors are good, it's the better image processing.
