What are the functions and colors of the wires in the Nikon MC-DC2 Remote Release Cord?
Thanks,
Jim
https://blog.kasson.com
Thanks,
Jim
The MC-DC2 has shutter release and shutter release lock, The cable is black.What are the functions and colors of the wires in the Nikon MC-DC2 Remote Release Cord? I need to set up a way for a Cognisys rail to fire the camera.
Thanks,
Jim
The colors I'm looking for are the colors inside the cable. Which is ground, which is shutter release, which is half-press? Are contact closures to ground what actualts the function?The MC-DC2 has shutter release and shutter release lock, The cable is black.What are the functions and colors of the wires in the Nikon MC-DC2 Remote Release Cord? I need to set up a way for a Cognisys rail to fire the camera.
Thanks,
Jim
That's good. Now I just have to figure out which is which.I’ve never chopped a Nikon cable so I can’t help with the direct question. But in triggering devices I’ve built I used the inexpensive camera specific cables from Vello etc to trigger the exposure, and a connection to a flash pc socket (or hot shoe) with the camera set to rear curtain sync to get an end of exposure signal.
All the lines in question are active low short-to-ground at low voltage.
On the ubiquitous 2.5mm tip-ring-barrel connector of the trigger cables you short the ring to the barrel to wake the camera and the tip to the barrel to fire the shutter.That's good. Now I just have to figure out which is which.I’ve never chopped a Nikon cable so I can’t help with the direct question. But in triggering devices I’ve built I used the inexpensive camera specific cables from Vello etc to trigger the exposure, and a connection to a flash pc socket (or hot shoe) with the camera set to rear curtain sync to get an end of exposure signal.
That looks helpful. Thanks.
No color guide, but this pinout may be of some help:What are the functions and colors of the wires in the Nikon MC-DC2 Remote Release Cord?
Thanks,
Jim
On some cameras at least that is alike to a half-press on the shutter button, thus triggering exposure metering and AF. The other one fires the shutter, but does not trigger metering or AF.you short the ring to the barrel to wake the camera
Right. But I just ordered one.Cognisys sells camera specific cables… maybe you don’t happen to have the right one on hand?
I’m uncertain about the connector on their end.
It does, indeed. Thanks.
Are you making some custom test equipment?Right. But I just ordered one.Cognisys sells camera specific cables… maybe you don’t happen to have the right one on hand?
No, this is for real photography. Hard to believe, I know…Are you making some custom test equipment?Right. But I just ordered one.Cognisys sells camera specific cables… maybe you don’t happen to have the right one on hand?
