pyloricantrum
Forum Enthusiast
- Messages
- 275
- Reaction score
- 39
I was wondering why the low light score for the A7S series has gotten worse since the release of the original A7S?
Sensor temperature has almost no effect on this type of measurement as it affects dark current noise, this really only affects long exposures unless the sensor temperature gets to some extreme level.A7S-A7SII and also A7-A7II both mkII having the same sensor as the mkI got lower high ISO results due to the IBIS unit. Well, not the unit in itself, but that it was harder to get a heat sink onto the sensor then, and a hotter sensor produces more noise.
I'm no expert in this field, I relayed what others said at the time the second generation bodys came and DXOmark measurement them. It sounded logically to me. I should have pointed that out in my first answer to the OP, sorry for that.Sensor temperature has almost no effect on this type of measurement as it affects dark current noise, this really only affects long exposures unless the sensor temperature gets to some extreme level.A7S-A7SII and also A7-A7II both mkII having the same sensor as the mkI got lower high ISO results due to the IBIS unit. Well, not the unit in itself, but that it was harder to get a heat sink onto the sensor then, and a hotter sensor produces more noise.
All kinds of reasons it could happen;I'm no expert in this field, I relayed what others said at the time the second generation bodys came and DXOmark measurement them. It sounded logically to me. I should have pointed that out in my first answer to the OP, sorry for that.Sensor temperature has almost no effect on this type of measurement as it affects dark current noise, this really only affects long exposures unless the sensor temperature gets to some extreme level.A7S-A7SII and also A7-A7II both mkII having the same sensor as the mkI got lower high ISO results due to the IBIS unit. Well, not the unit in itself, but that it was harder to get a heat sink onto the sensor then, and a hotter sensor produces more noise.
If you are better knowledgeable about sensors then maybe you can explain why the same sensor got worse high ISO performance in the second generation bodys?
The problem with DXOMark is that they define arbitrary scores that don't make sense, and the overall score is just an average of 3 scores (portrait, landscape, sports), which again doesn't make sense. You can't just take the average of 3 different things. If one of them is near 0, the overall score might still be high because of the average, but in fact it should be near 0.I was wondering why the low light score for the A7S series has gotten worse since the release of the original A7S?
