In order to run BSG 8.4 you need to use the older Magisk mod (found from here: https://drive.google.com/file/d/12O9C7ZYENVqS_lyNFLj4CZlQiA287VTo/view?usp=sharing)Thanks for adviceI forgot to mention the config and GCam in my previous post is meant for 12mp output. If you want to use 48mp, use the high res Magisk mod and latest BSG 8.4 GCam. It can load libraries, just load the Dimifix_8.4.so and there you go,Sadly not working with my Mi10 ULTRA, proably i must try install other MIUI version and then will work. I don't know is this worth? Can You tell me is image blurry on phone screen like on 8.1 GCAM version? This is only one issue i don't like when using fullres mod.
BTW: If someone is interested - i found solution to take brighter photos using GCAM 8.1 and fix focusing issues. You need disable library recomended to use with this GCAM version(libgcstartup11 ). Images maybe look a little bit worse, but they are brighter and focusing issues disappearHere some samples straight from camera and even not in HDR+. In this mode You can shoot without waiting to processing photo, not bad at all
Of course HDR+ is bit better and less noisy, but in daylight this quality is fair enhough.
Just disable the "new" mod you use with 8.1 and flash this with Magisk. Then install BSG 8.4 and select Dimifix lib and there you go. Should work.
Couple of samples:
