Phil and Karen
Hi Bruce,Will have a look into this. I presume if you process the RAWs through PureRAW and then import the DNGs into LR, you turn off all lens correction in LR?
My understanding is DXO lens corrections are of very high quality - in fact, I've been finding areas of my images I never knew existed. Check the below example screen dump showing a direct import to LR on the left and an import via PL4 on the right. Note the bird's claw.
(It doesn't matter what I do with the direct import into LR I can't get the full image to show).
I've found if I apply lens corrections again in LR it crops images. (As I'm brand new to PL4 I'm still exploring the finer points of this particular aspect, but I think I'll end up just using the files as sent across by PL4 without applying the lens corrections a second time in LR).
Phil
