I made a quick "equivalence" chart (full stops)
Supisiche
The chart assumes that you stand at the same distance to the subject with 3 different cameras (full frame, aps-c *1.5*, and micro four thirds *2*) and that you use equivalent focal lenghts to achieve the same angle of view (75mm ff > 50mm apsc > 25mm m43).
The chart tells you the needed f-number to keep the same aperture diameter (viewed from the front of the lens) for all formats. I used a calculator, so "3.73" could be f/3.5 or f/4 (a bit more/less light). Enjoy :)
Whenever I'm out shooting with my friends and we have 3 types of sensors we can use this so we can be the same.
Seriously why is this important if you're shooting pics with your own camera?
What if you use a camera from your friends? (ノ◕ヮ◕)ノ
A+ for positivity and gumption.
Seriously, some people have been known to own cameras with different sensor sizes.
37.5mm m43, in the case you cite
Might be handy for some people. How have you been using it?
cheers
I have a m43 (not mine), an old canon powershot and I sold my D3300 this week. I have little money, only enough to get a D700 or a 5D mark ii, which one is better? I heard the D700 doesnt have video and the D600 I got months ago was in pretty bad shape. Can you help me? Thanks :)
cheers
I use it to compare primes or zoom lenses. I am interested in low light performance.
Guess I don't understand what the chart is about. Is it something to do with depth of field when using lenses on different sensor sizes?
Yes, same dof and same amount of light entering the front of the lens.
I can go along with some possible dof effects, but what size sensor is behind lens has no effect whatsoever on how much light enters the front of the lens or exits the back of the lens. How could sensor size change the physical properties of a lens? Sensor only records whatever portion of the image circle projected by the lens that it covers. How much of the image circle you record with sensor can not change what is in that image circle.
I know but the chart assumes that you use a shorter lens in the smaller sensor camera.
Why would you care about the amount of light in the image circle if only a subset of it hits your sensor?
