Review of Opteka 6.5mm f/3.5 Fisheye lens.
jvc1
Pittsburgh, PA
I've been wanting an ultra wide lens for my APS-C Canon 90d and found the Opteka 6.5mm f/3.5 lens on sale for $140 USD. and decided to give it a try. This is a manual APS-C lens with a 180 deg. diagonal field of view.
The build quality is quite good, metal mount and barrel with a large, smooth operating rubber focus ring. The aperture ring has fixed stops at f/3.5 and f/5.6 then every 1/2 stop to f/22. Another fixed position between f/3.5 and f/5.6 would have been nice however there is room to position the ring between these stops but you don't know exactly what your getting. The hood can be removed but you need it in place to install the cap.
This is a manual focus lens, the depth of field is so deep that even at f/3.5, if you use the distance scale to pick the approximate critical spot you'll be good. The MFD of this lens is 11.8 inches presenting some interesting possibilities. Focusing at the MFD gets a little more difficult if you want the sharpest possible images. Live view X 10 helps for this.
Image quality. Wide open, images are pretty soft in the center and a little softer as you move towards the edges. Sharpness improves a lot at f/5.6. Depending on the lighting, there's a lot of CA at f/3.5, this too improves at f/5.6 but is still visible in the 2 images below.
This one is at f/3.5, nothing is all that sharp and there's heavy CA, especially in the branches in the upper right. (SOOC JPEG)
This one is at f/5.6, the sharpness improves a good bit and the CA is less obvious but still there. (SOOC JPEG)
Just had to do the brick wall, these are at the MFD.
This one @f/3.5, not all that sharp. (SOOC JPEG)
This one at f/5.6, the sharpness improves a lot. (SOOC JPEG)
The color and contrast very closely match the actual scenes.
My conclusion is that if you're a pixel peeping addict who just can't let it go in ultra wide images you may want to pass. If though, you want an ultra wide lens that's cheap and, with a little work and PP, can deliver some decent and unusual images (I'd avoid f/3.5 as much as possible) I think it's worth the very small investment. My rating does take the low cost of this lens into consideration. I'd rate it lower if it cost several hundred dollars.
I keep some of my favorite pictures here,
I don't use it very often but my wife bought me one of these a few Christmas ago, to use on my Sony a3000. Really fun to use. This one taken at Long Beach on Vancouver Island.
Peter Davies
Many thanks for the review and for posting the JPGs.
I thought you might be interested to see how the photos from the Opteka 6.5mm F3.5 lens look when they are "de-fished".
so
[1] here is your image de-fished and cropped to the same size as the original
[2] here is the image de-fished and uncropped - and now you see why we try to keep fisheye lenses level as the keystone distortion is severe!
[3] and here is the uncropped de-fished image then levelled up using DXO perspective
The more you can level up the lens as you take the picture the wider we can renconstruct the image in rectilinear format. At the moment it is down to a 1:1 square format sort of view...but I think it looks great !
You don't need DXO to do this - there is a free software called "Hugin" you can get that works on Mac or PC and there are You Tube and other "how to" step-by-step instructions to follow.
Best wishes - Paul C
PS - composing with fisheyes is hard; you need a lot of time to think out each set up.
I use a lot of fisheye, but when time is short I love the Sigma 10-20mm lens for APS cameras as composing is easy since the image is already rectilinear;
in 2024 secondhand copies of the mark 1 variable-aperture Sigma is inexpensive on web selling sites such as MBP. I got a mint one only a few months ago and love it.
