Rebels and focus microadjust
Started Jul 27, 2020 | Discussions
Panet
Panet Senior Member • Posts: 2,141
I was  considering a Tamron 150-600mm to use with a T4i. Talking about with some mates, I heard some tales about bad performance in getting sharp focus with this sort of combo. is focus microadjust a must?
Dum senesco, addisco.
Canon EOS Rebel T4i (EOS 650D / EOS Kiss X6i)
Digirame Forum Pro • Posts: 41,857
Re: Rebels and focus microadjust
I think it may depend on the copy.  I have successfully used the Tamron 150-600mm lens with a Canon T3i (600D) camera and Canon T7i (800D) camera without MFA.  Lately, I have been exploring whether the images are soft at 600mm FL.  It seems if I don't hold the camera steady enough at full focal length, then it's been my fault.  I know when I get sloppy by moving the lens too much even at fast shutter speeds, then I noticed the soft images when I zoomed up to look at them in detail.  This past weekend, I concentrated on holding the lens more steady, and I got positive results; that is the images were much sharper.
Here's one example at 600mm FL.  I show many more examples of photos with that lens weekly on the Show Your Snaps thread.
You could take a chance to see how that lens does with the Canon T4i (650D) camera.  If it does look like it needs MFA, then you might look at something different like the Canon 80D or 90D.
adventurer69
adventurer69 Senior Member • Posts: 1,942
I was wondering the same thing , all  of my T3i images are are lightly out of focus regardless of what lens I used
 adventurer69's gear list:adventurer69's gear list
Canon PowerShot A590 IS Canon PowerShot SD880 IS Canon PowerShot SX50 HS Canon EOS M Canon EOS M50 +11 more
Have you determined why?  Is it "user error" (like in my case) or a depth of field issue with the camera?  Normally, I can hold the smaller lens steady, but that large Tamron 150-600 lens is a "beast" and it's easy to not hold the camera/lens steady.  I noticed if I'm not careful, that I'll drop the lens ever-so-slightly because of the weight when I'm taking the picture.
adventurer69
I don't have the issue with any other of my cameras .
benjilafouine Veteran Member • Posts: 3,875
The best way to know is to shoot at 1/1600. If it is still blurry, it may be an out of focus issue and then MFA is a good tool (if you are very very patient). I used to follow the rule of speed equals to 1/focalsize but in the end, most of my issues were shutter speed. For example, if you have a 400 mm lens on a crop sensor camera, your shooting speed should be at least 1/640 for static scenes. For moving targets (birds for example), you have to be at least 1/1000 and even 1/1600 if you want to freeze the action or otherwise, you may end up with some motion blur.
Also, for a small bird at close distance, f5.6 may not be enough, you may have to go f6.3 if you want the whole bird to be in focus. This page is interesting to calculate DOF: https://www.dofmaster.com/dofjs.html
Since I adopted these two rules, my pictures became much better!
There is always something to shoot/snap, you just have to know how to do it and have the right gear.
Benji
 benjilafouine's gear list:benjilafouine's gear list
Canon PowerShot S5 IS Canon PowerShot SX110 IS Panasonic Lumix DMC-FZ35 Canon PowerShot G16 Canon EOS 40D +12 more
adventurer69
Thank you Benji , I'll look into it .
Ad12 Senior Member • Posts: 1,514
Don’t quote me, as my rebel and Tamron 100-400 seem good out of the box, but i read that you can tweak focus in the Tamron tap in console, but it costs to buy. Not sure if that’s true, but maybe look in to it.
 Ad12's gear list:Ad12's gear list
Nikon D500 Nikon Z6 Sigma 150-600mm F5-6.3 | C Sigma 100-400mm F5-6.3 Nikon Z 24-70mm F4
Duckman21 Regular Member • Posts: 273
If OP is talking about the G1, then no, you cannot use the Tap-in Console. Only the 150-600mm G2 works with. In my experience, there are inconsistencies with the AF, often a tendency to front-focus on objects about 20m away. The Tap-In should work in theory but it is a tedious process to calibrate and I haven't had much success - I find the built-in microadjustment of the 80D much more effective (albeit it must be constantly adjusted).
I shot with a Rebel while my 80D was under repair and it occassionally struggled to get objects in focus but worked fine for the most part. I used the back button for manual override (the opposite of back-button focus)
Instagram @FYLegend21
500px @frankyboy5
 Duckman21's gear list:Duckman21's gear list
Canon EOS Rebel T6s Canon EOS R6 Canon EF-S 18-135mm F3.5-5.6 IS STM Tamron SP 150-600mm F5-6.3 Di VC USD G2 Canon RF 800mm F11 IS STM
adventurer69
can rebels be micro adjusted , I have a T3i that can't seem to focus right at anytime .
No, unfortunately. Only 80D, 7D, 5D and up can. I am 100% sure about your cam. However, if you want to help it, close down a bit your aperture, this will augment the depth of field. Did that and it really helps!
Benji
adventurer69
I think I would just give up on it altogether .:-(
stevet1 Senior Member • Posts: 1,300
I have a side question:
If you have an AF button on the back, do you keep the button pressed while you manually micro adjust your focus, or do you release the button and then manually adjust?
Steve Thomas
 stevet1's gear list:stevet1's gear list
Canon EOS Rebel T8i (EOS 850D) Canon EF-S 55-250mm f/4-5.6 IS STM Canon EF 50mm F1.8 STM Canon EF-S 18-135mm F3.5-5.6 IS USM
Steve Thomas
You need to first set the AF button to AF-OFF. After you do this, you must keep the button pressed to continue manual override.
Many people resort to back-button focus. If you have disabled the shutter half-press for AF, then having no buttons pushed means full-time manual focus.
500px @frankyboy5
