Doug Willis
Active member
Has there been any developments in Sony Alpha cameras to facilitate better timecode capabilities? Whilst I am aware that Sony Cameras have a Timecode clock internally, I am not aware of anyway to Jam sync the camera Timecode clock with a master timecode clock. Most of the external timecode devices (Tentacle, etc) appear to work by writing timecode to an audio channel (not the metadata), which has the effect of making the Cameras internal Timecode clock useless. This seems a waste to me.
One solution I have seen to reset the camera/s internal timecode clocks is to use an old Sony remote (very expensive used on eBay), but this solution will only reset two cameras to be synched with each other, it does not sync with a master for other devices like an audio recorder or other branded cameras. Again not really ideal. If you do not have the old remote (which I think uses IR signal), I do not know another way to sync two cameras apart from trying to press the reset button on both cameras simultaneously. Again not ideal. I also dont think that Sony's Imaging edge Mobile app can reset timecode on even one camera, let alone multiple (Sony) cameras at the same time.
What is needed here is something akin to Timecode Systems Ultrasync Blue which purports to be able to master clock sync several devices similtaneously using bluetooth, but as I understand it at present, it only seems to work with smartphones and tablets ( a bit limited). The tentacle type solutions need a seperate (and expensive) device to be attached to each device (camera or recorder) and do not work with action cams like GoPro or insta360. I belive the Sony action cams have a timecode clock, but like the cameras cannot be bluetooth reset or synched.
It seems to me that camera manufacturers could easily (and cheaply) implement better timecode synching solutions with existing widespread technologies like bluetooth or WiFi to an industry standard without cannabalising higher end professional gear sales.
Perhaps if enough people agree with this, the industry will take note and do something.
