I'm an amateur shooting the Fuji X-T2 with the XF 100-400 for a couple of years now. Coming from compact cameras I was blown away by the image quality improvements this combo gave me. As I'm getting used to this quality and my skills improve I'm wondering: Could it be better? I'm sometimes disappointed by long distance shots as they come out quite soft no matter what shutter speed. Having no experience with other camera systems at those focal lengths I wondered if that's due to physics (air diffusion) or due to the lens.
To find out the truth I rented a Sony A7 III with the Sony FE 100-400mm F4.5-5.6 GM OSS and the 1.4x TC.
Sony 100-400 gets excellent reviews in terms of sharpness at the long end so it's a good reference. I chose this combo because I don't consider lenses weighing more (like the Sony 200-600) or more expensive/higher resolution/non-mirrorless bodies. I'm usually photographing on long hikes and bicycle travels - and I don't feel dedicated enough to photography to justify that gear to myself.
Questions to sort out:
https://www.dpreview.com/galleries/3521449058/albums/fuji-100-400-vs-sony-100-400-1-4-tc
Results:
Changing the camera system would not improve my pictures and I can stay happy with what I have.
- Does the Fuji 100-400 produce relatively soft images at long distances due to the lens itself or air diffusion?
- Does the full frame combo provide a better image quality for about the same weight?
- Is the Sony lens sharper at 400mm (without TC) than Fuji at the same equivalent focal length?
- Multiple shots with refocussing inbetween (at least 3). Then I chose the best one per combo.
- All handheld (I never use tripods).
- All shots outdoors in realistic situations except image sets Gull 1 and Gull 2
- I didn't try to keep equivalency of ISO/Aperture/Shutter speed. Light situation outdoors was changing and impact on image quality is insignificant if you don't pixel peep.
- All pictures processed in Lightroom with Adobe Color profile and manual adjustments to white balance and exposure to match them as close as possible. Sharpening for Fuji photos is set to Amount 100/Details 0 (read more on that at https://exploringexposure.com/blog/fujifilm/my-fujifilm-sharpening-workflow-in-lightroom)
- All shots resized to 4K resolution as this is how I look at them mostly.
Results:
- The relative softness at long focal lengths is not due to the lens. The pictures from the two combos look about the same. I just have too high expectations given the atmosphere on planet earth and I should listen to professional wildlife photographers: Get closer to your subject if you want better picture quality. Image sets: Heron, Crow, Pelican, Cormorant
- In my opinion the full frame combo produces the same or slightly better pictures. But nothing which would improve my photography and justify the much higher cost. But: Variability between the multiple shots I took of the same subject is significantly higher on the Fuji combo. Something I observed with any lens on the on the XT-2 and I get more consistent results using electronic shutter (ES) at any shutter speed. XT-2 doesn't have electronic first curtain shutter and the shutter release button is quite stiff (I prefer the Sony one). XT-4/X-H2 might improve that but I don't wory about using ES.
- Sony at 400mm (no TC) and Fuji at almost equivalent 261mm show no significant differences to me. Image set: Gull 2
