I'm helping someone with a computer issue. They are complaining about a slow performing computer. It has 4GB of ram and a little less than half is free. Hard drive is mostly empty. I did some basic checks such as a virus scan and it seems okay.
I wonder if there is any significant benefit to increasing the memory? User is not in a position to upgrade to a new machine at this point.
What is the computer being used for? What version of Windows are they using ?
Complaining about a slow performing computer on what ? Boot Up, running Adobe etc?
Is it being used for Hard Disk intensive, graphics intensive, memory intensive Use.
You can download performance tests to check it out, and it may not be slow at all?
SSD will help on boot up, as when you click on a new program to start it, it comes up on the screen pretty quick.
If you are using graphic intensive programs, like 4k Video, 42 meg Raw photography files, you need a good graphic card. Graphic cards would be the slowest part of the system with the present 16 bit processing, large data files and intensive graphic calculations using Adobe. Likewise a good monitor to display the same.
Increase in Memory is also greatly needed, 4 GB is the minimum requirement for Windows which can be used for simple browing, email and Office Tasks. You really cannot use it much with the present large programs of Adobe etc today?
Even the Virus programs will slow down to a crawl with that memory.
With inadequate resources on the computer, more Advanced Windows OS will be slower, than the older windows. In other words, every upgrade in Windows will require more memory, more hd, better graphic card etc.
