FUJFIILM X-T4 full specs Leaked (full list here)
Power X
Active member
Number of effective pixels 26.1 millions pixels
Image sensor
23.5mm x15.6mm (APS-C) X-Trans CMOS 4 with primary color filter.
Sensor Cleaning system Ultra Sonic Vibration
Storage media
SD memory card (-2GB) / SDHC memory card (-32GB) / SDXC memory card (-512GB) UHS-I / UHS-II / Video Speed Class V90
File Format
Still image JPEG: Exif Ver.2.3, RAW: 14bit RAW (RAF original format) TIFF: 8/16bit RGB
Number of Recorded Pixels
L: (3:2) 6240 x 4160 / (16:9) 6240 x 3512/ (1:1) 4160 x 4160 M: (3:2) 4416 x 2944/ (16:9) 4416 x 2488/ (1:1) 2944 x 2944 S: (3:2) 3120 x 2080 / (16:9) 3120 x 1760 / (1:1) 2080 x 2080
Movie
MOV (MPEG-4 AVC/H.264, HEVC/H.265, Audio: Linear PCM / Stereo sound 24bit / 48KHz sampling), MP4 (MPEG-4 AVC/H.264, Audio: AAC)
Sensitivity
Standard output sensitivity: AUTO1 / AUTO2 / AUTO3 (up to ISO12800) / ISO160-12800 (1/3 step)
Extended output sensitivity: ISO80/100/125/25600/51200
Exposure control
TTL 256-zone metering, Multi / Spot / Average / Center Weighted
Exposure Modes
P (Program AE) / A (Aperture Priority AE) / S (Shutter Speed Priority AE) / M (Manual Exposure)
Exposure compensation
-5.0EV – +5.0EV 1/3EV step
Movie recording
-2.0EV – +2.0EV
Image Stabilizer Mechanism
Image sensor shift mechanism with 5-axis compensation
Image Stabilizer Compensation Effect
Maximum 6.5 stops (based on CIPA standard. Pitch/yaw shake only. With XF35mmF1.4 R lens mounted.)
Digital Image Stabilizer
Yes (movie mode only)
IS Mode Boost
Face / Eye detection AF
Yes
Shutter type
Focal Plane Shutter
Mechanical Shutter
P mode: 4sec. to 1/8000sec. A mode: 30sec. to 1/8000sec. S/M mode: 15min. to 1/8000sec. Bulb mode: up to 60min.
Electronic Shutter
P mode: 4sec. to 1/32000sec. A mode: 30sec. to 1/32000sec. S/M mode: 15min. to 1/32000sec. Bulb mode: 1sec. Fixed
Electronic Front Curtain Shutter
Mechanical + Electronic Shutter
P mode: 4sec. to 1/32000sec. A mode: 30sec. to 1/32000sec. S/M mode: 15min. to 1/32000sec. Bulb mode: up to 60min.
E-Front + Mechanical Shutter
Electronic front curtain shutter works until 1/2000sec.
E-Front + Mechanical + Elec. Shutter
Electronic front curtain shutter works until 1/2000sec, Mechanical shutter works until 1/8000sec.
Movie Shutter
FHD: 1/8000sec. to 1/4sec.
DCI4K/4K: 1/8000sec. to 1/24sec. (depends on the frame rate)
Synchronized shutter speed for flash
1/250sec. or slower
Continous Shooting
Approx. 30fps [Only electronic shutter, 1.25 x Crop ] (JPEG: 60 frames Lossless compressed RAW / Compressed RAW: 35 frames Uncompressed RAW: 33 frames)
Approx. 20fps [Only electronic shutter, 1.25 x Crop ] (JPEG: 114 frames Lossless compressed RAW / Compressed RAW: 37 frames Uncompressed RAW: 34 frames)
Approx. 10fps [Only electronic shutter, 1.25 x Crop ] (JPEG: 500 frames Lossless compressed RAW / Compressed RAW: 48 frames Uncompressed RAW: 39 frames)
Approx. 20fps [Only electronic shutter ] (JPEG: 79 frames Lossless compressed RAW / Compressed RAW: 36 frames Uncompressed RAW: 34 frames)
Approx. 15fps (JPEG: 110 frames Lossless compressed RAW / Compressed RAW: 38 frames Uncompressed RAW: 35 frames)
Approx. 10fps (JPEG: 164 frames Lossless compressed RAW / Compressed RAW: 44 frames Uncompressed RAW: 37 frames)
Approx. 8fps (JPEG: 200 frames Lossless compressed RAW / Compressed RAW: 49 frames Uncompressed RAW: 39 frames)
Pre-shot
Approx. 30fps [Only electronic shutter, 1.25 x Crop ] (max. 20 frames while half press, max. 20 frames after full press, total max. 40 frames) Pre-shot: Approx. 20fps [Only electronic shutter, 1.25 x Crop ] (max. 20 frames while half press, max. 37 frames after full press, total max. 57 frames) Pre-shot: Approx. 10fps [Only electronic shutter, 1.25 x Crop ] (max. 10 frames while half press, max. 300 frames after full press, total max. 310 frames)
Auto Bracketing
AE Bracketing (Frames: 2, 3, 5, 7, 9 Step: by 1/3EV step, up to +/-3EV steps) Filmsimulation bracketing (Any 3 types of film simulation selectable)
Dynamic Range Bracketing (100%, 200%, 400%)
ISO sensitivity Bracketing ( +/-1/3EV, +/-2/3EV, +/-1EV)
White Balance Bracketing ( +/-1, +/-2, +/-3)
Focus Bracketing (AUTO, MANUAL)
Focus Mode
Single AF / Continuous AF / MF
Focus Type
Intelligent Hybrid AF (TTL contrast AF / TTL phase detection AF)
Focu Low-Light Performance
Contrast: -3.0EV Phase Detection: -6.0EV (XF35mmF1.4 attached)
Focus AF Frame Selection
Single point AF: EVF / LCD: 13×9 / 25×17 (Changeable size of AF frame) Zone AF: 3×3 / 5×5 / 7×7 from 91 areas on 13×9 grid
Wide/Tracking AF, AF-S: Wide / AF-C: Tracking All
White Balance
Auto (WHITE PRIORITY, AUTO, AMBIENCE PRIORITY), / Custom1-3 / Color temperature selection (2500K-10000K) / Preset: Fine, Shade, Fluorescent light (Daylight), Fluorescent light (Warm White), Fluorescent light (Cool White), Incandescent light, Underwater
Self-timer
10sec. / 2sec.
Interval Timer Shooting
Yes (Setting: Interval, Number of shots, Starting time)
Flash Sync Mode
1ST CURTAIN / 2ND CURTAIN / AUTO FP(HSS) (excl. EF-X8)
Flash Mode
TTL (TTL AUTO (P mode) / STANDARD / SLOW SYNC. ) / MANUAL / COMMANDER / OFF (When EF-X8 is set)
TTL (TTL AUTO (P mode) / STANDARD / SLOW SYNC. ) / MANUAL / MULTI / OFF (When SHOE MOUNT FLASH is set)
Hot Shoe
Yes (Dedicated TTL Flash compatible)
Viewfinder
0.5 inch approx. 3.69 millions dots OLED Color Viewfinder
Coverage of viewing area vs. capturing area: approx. 100%
Eyepoint: approx. 23mm (from the eyepiece lens)
Diopter adjustment: -4-+2m-1 (lockable)
Magnification: 0.75 x with 50mm lens (35mm equivalent) at infinity and diopter set to -1m-1
Diagonal angle of view: approx. 38 Degree (Horizontal angle of view: approx. 30 Degree )
Built-in eye sensor
LCD monitor
3.0 inch, aspect ratio 3:2, approx. 1.62 millions dots touch screen color LCD monitor (approx. 100% coverage)
Movie Recording File Format
Movie Recording Compression
All Intra/Long-GOP
DCI4K/4K 29.97p/25p/24p/23.98p 400Mbps Full HD (2048 x1080)/ Full HD (1920×1080) 59.94p/50p/29.97p/25p/24p/23.98p 200Mbps
Movie File Size/Frame Rate/Rec. Time
[DCI 4K (4096 x2160)]59.94p/50p/29.97p/25p/24p/23.98p 400Mbps/200Mbps/100Mbps 59.94p/50p: up to approx. 20min. 29.97p/25p/24p/23.98p: up to approx. 30min
[4K (3840×2160)]59.94p/50p/29.97p/25p/24p/23.98p 400Mbps/200Mbps/100Mbps 59.94p/50p: up to approx. 20min. 29.97p/25p/24p/23.98p: up to approx. 30min
[Full HD (2048 x1080)] 59.94p/50p/29.97p/25p/24p/23.98p 200Mbps/100Mbps/50Mbps up to approx. 30min.
[Full HD (1920 x1080)] 59.94p/50p/29.97p/25p/24p/23.98p 200Mbps/100Mbps/50Mbps up to approx. 30min.
[Full HD (1920 x1080) High speed rec.] 240p / 200p 200Mbps(recording) up to approx. 3min. 120p / 100p 200Mbps(recording) up to approx. 6min.
Film Simulation mode
18 modes (PROVIA/Standard, Velvia/Vivid, ASTIA/Soft, Classic Chrome, PRO Neg.Hi, PRO Neg.Std, Black & White, Black & White+Ye Filter, Black & White+R Filter, Black & White+G Filter, Sepia, ACROS, ACROS+Ye Filter, ACROS+R Filter, ACROS+G Filter, ETERNA/Cinema, Classic Neg, ETERNA BLEACH BYPASS) Monochromatic Color
Clarity Setting
+/-5 steps
HDR Mode
AUTO, 200%, 400%, 800%, 800% +
Grain Effect
Roughness: STRONG, WEAK, OFF Size: LARGE, SMALL
Color Chrome Effect STRONG, WEAK, OFF
Color Chrom Effect Blue STRONG, WEAK, OFF
Dynamic Range Setting Still
AUTO, 100%, 200%, 400%
ISO restriction (DR100%: No limit, DR200%: ISO320 or more, DR400%: ISO640 or more)
Dynamic Range Setting Movie
100%, 200%, 400%
Advanced Filter
Toy camera, Miniature, Pop color, High-key, Low-key, Dynamic tone, Soft focus, Partial color (Red / Orange / Yellow / Green / Blue / Purple)
Wireless Transmitter Standard
IEEE802.11b/g/n (standard wireless protocol)
Wireless Transmitter Encryption
WEP / WPA / WPA2 mixed mode
Wireless Encryption Access mode Infrastructure
Bluetooth Standard
Bluetooth Ver 4.2 (Bluetooth low energy)
Bluetooth Operating frequency
2402 – 2480MHz (Center frequency)
Terminal
Digital interface: USB Type-C (USB3.2 Gen1x1)
HDMI output: HDMI micro connector (Type D)
Other: 3.5mm, stereo mini connector (Microphone) / 2.5mm, Remote Release Connector, Hot shoe, Synchronized terminal
Power supply
NP-W235 Li-ion battery (included)
Battery life for still images
Approx. 600 frames (Economy Mode), approx. 500 frames (Normal Mode) When XF35mmF1.4 R is set.
Actual battery life of movie capture Face detection is set to OFF
[4K] approx. 85min. (29.97p) [Full HD] approx. 95min. (59.94p)
Continuance battery life
[4K] approx. 110min. (29.97p)
[Full HD] approx. 130min. (59.94p) (movie capture)
Operating Temerature
-10 Degree C-+40 Degree C
Operating Humidity
10%-80% (no condensation)
Battery
Li-ion battery NP-W235
Starting up period Approx. 0.39sec.
Dimensions (D x W x H)
63.8 x 134.6 x 92.8 mm
Weight
Approx. 607g (including battery and SD memory card) Approx. 526g (excluding battery and SD memory card)
The more I read of these specs the more I think I will stick with my X-T3, and buy either an X-Pro3, or X100V to satisfy my GAS urges.
Wow. I was looking for this: Compressed RAW: 36 frames Uncompressed RAW: 34 frames. One heck of a buffer. Unfortunately, not that much better than my X-H1. In fact, aside from the bigger battery (which I don't need), the improvements needed for ME are few. However, I'll bet the camera sells like crazy.
Nice post. Thanks.
Awesome upgrade to the X-T line.
Nice post. Thanks.
According to the chart on the rumor site the X-T4 buffer is more than 50% better than a X-H1 at 8fps.
The X-T4 seems like the perfect upgrade for me except for the flippy screen as I am primarily a stills-shooter. Not a deal breaker but a definite inconvenience.
Can't wait to pair my 90 f2 with IBIS!
To be honest this new strategy makes me wonder what they have in store for the X-H2.
Same here. I'd bet the X-H2 gets the new Sony sensor that has been discussed in these forums. If the new sensor is the 40 some odd megapixel, that would be a huge jump and would likely satisfy a lot of the X-H crowd.
Nice post. Thanks.
The chart on the rumor site also talks about “multiple boost modes” including “boost AFC” and “boost FPS”. I wonder if that would mean improved tracking; something I would really like to see implemented.
I am really disappointed with this spec because it doesn't come in pink. Time to switch to Sony, Nikon, Canon......
If you pay less attention to the differences between X-T3 and X-T4 and instead focus on what the X-T4 actually offers it's pretty obvious that this is (at least on paper) a very capable camera that will satisfy most people. You can't expect a revolution for a product that is released (almost) annually.
.lars
Battery life 500/600 frames. Is that CIPA rating?
Other specs are fine but I am disappointed by the weight increase, almost the double of my a6000, and 100g more than the a6600.
and the 30s (or less) video recording limit, even in 1080p (I film concerts)
I am very curious about any autofocus improvement.
I will reconsider the Sony A6600, although it has other drawbacks (only one SD, and UHS1 only, no dials...)
Agreed. Have an X100V on pre-order.
