AlwynS
The efficacy or not of the new firmware 2.0 release for the RX10 IV has been discussed in some other threads. I have recently installed the new firmware and wanted to find out whether/how it works.
This morning, I went to a local migratory bird park (Reifel) with my good friend Steve (evetsf on this board) from Bellingham, WA . This was a good opportunity to check the Animal Eye AF on birds. And I have come to a pretty much unequivocal conclusion:
With slow moving birds on the ground and on water, VERY close up, Eye AF works as advertised. BIF or birds NOT filling a very significant part of the frame: no way. Things get tricky where the eye is relatively close and the bird moving slowly BUT the eye is hard to distinguish, e.g. black eye in a black head. Which should probably not be a surprise.
When I say close up, the following shows where I found Eye AF typically worked for me. Note that all items are cropped to no smaller than 3840 x 2160 with several being larger than that.
Eye tracking recognised they eye on this Coot and generally even held on when he started turning his head away until they eye was essentially fully obscured.
Similar to the Coot
Generally tracked:
Some unsuccessful examples to follow.
Note that when I used Flexible Spot, once the Eye Focus locked on and started tracking, it immediately lost tracking when the eye went outside the Flexible Spot. Something to bear in mind.
Cheers
Alwyn
Similar to the Coot
Generally tracked:
Cheers
Alwyn
