New lens suggestions for Landscape/Street/Structure Photography
Started Aug 2, 2019 | Questions
thenoobphotographer
thenoobphotographer New Member • Posts: 9
Hello Everyone,
I am a beginner photographer. I do mostly Landscape (scenic), Street and Structures photography. I do little portrait photography. I currently have Canon t7i with the 18-135mm kit lens.
I am in the market for a new lens preferable better for Landscape photography. I am confused between the Canon 24mm f2.8 vs Canon 10-18mm. Any suggestions between these two?
Do you recommend any other lens from Canon or Sigma?
Thanks, in advance for your feedback!
 thenoobphotographer's gear list:thenoobphotographer's gear list
Sony a7R III Sony FE 90mm F2.8 macro Zeiss Batis 85mm F1.8 Sony FE 100-400mm F4.5-5.6 Sony FE 24mm F1.4 GM
Canon EF-S 18-135mm F3.5-5.6 IS STM Canon EOS Rebel T7i / EOS 800D / Kiss X9i
Ed Rizk Veteran Member • Posts: 3,898
Re: New lens suggestions for Landscape/Street/Structure Photography
If you use a tripod, the 10-22 is a better piece of glass.    The 10-18 is stabilized, so it could be the better choice for hand held shooting.
The 10-22 was my favorite and most used lens, when I had the 60D.
The only other UWA I would consider for APSC is the Sigma 8-16, because wider is better.   It was not available when I bought my 60D.   I still might choose a Canon lens, because the 8-16 has a weird mustache distortion that is more noticeable and harder to correct than the others.
UWA is where it’s at.   You will love any of those.
Ed Rizk
 Ed Rizk's gear list:Ed Rizk's gear list
Canon EOS 6D Canon EOS R Canon EF 17-40mm f/4.0L USM Canon TS-E 17mm f/4L Canon EF 24-70mm F4L IS USM +4 more
Dave
Dave Veteran Member • Posts: 6,231
While 24mm isn't that wide on crop, I still find mine very handy.
 Dave's gear list:Dave's gear list
Canon EOS 80D Canon EF 135mm F2L USM Canon EF-S 17-55mm f/2.8 IS USM Canon EF 100mm F2.8L Macro IS USM Canon EF 70-300mm f/4-5.6L IS USM +10 more
Julia Schott
Julia Schott Forum Member • Posts: 89
40mm f/2.8 pancake for everything.
ffabrici Senior Member • Posts: 1,353
I would strongly recommend a 10-22mm zoom for landscabe/street/structure.
Andy01 Veteran Member • Posts: 5,191
A 40mm on APS-C for landscape - best get good at stitching panos together
Colin
 Andy01's gear list:Andy01's gear list
Canon EOS M5 Canon 6D Mark II Canon EF 100mm F2.8L Macro IS USM Canon EF-M 22mm f/2 STM Canon EF 35mm F2 IS USM +5 more
BAK Forum Pro • Posts: 26,020
Buy a polarizer and use the lens you own.
BAK
Klaus dk
Klaus dk Veteran Member • Posts: 9,760
Huh???
BAK
 Klaus dk's gear list:Klaus dk's gear list
Sony RX100 II Canon EOS R Canon EOS R5 Canon EF 16-35mm F4L IS USM Canon RF 24-105mm F4L IS USM +7 more
Steve Balcombe Forum Pro • Posts: 15,582
Agreed. When I was using my 10-22 it's surprising how often I wished for IS. It's sometimes argued that IS is less useful for wide angle lenses, but if you shoot in low light this is not true.
I now have a 16-35/4L IS on full frame, which is the perfect solution but a bit more expensive.
Re: Huh???
Easy. Sorry to confuse you.
The easiest way to improve landscaape photographs is to use a polarizer.
It cuts glare not only on lakes and rivers, but on shiny foliage and glass windows in urban landscapes.
The 18mm point on his current lens will put lots of interesting subject matter in his photographs. As will the 20 and 21 and 22  mm points.
And longer settings, if perchance he is photographing a castle across a valley.
Once he takes ten frame-worthy pictures with what he's got, he can go buy a wider lens.
BAK
BlueRay2 Forum Pro • Posts: 14,816
BAK
Hahaha...dude, get a grip
You miss 100 percent of the shots you didn't take!!! "Wayne Gretzky"
Re: Huh???
yeah, and then deal with cast they leave behind
BAK
1Dx4me wrote:
BAK
I thought a grip would be more useful for sports photography
Ed Rizk
Ed Rizk wrote:
1Dx4me wrote:
BAK
sure, i go long with that but i thought BAK was a bit off the mark with that comment.
