Can you tell me please how the resolution of your Brick at f2.8 compares to that of your 35mm f1.4 at f2.8 and your 16mm f1.4 at f2.8? I ask as when I tested my copy of the Brick it didn’t seem to live up to its reputation and I have a few days of the ‘return window’ left.
Let me say first of all that I do take real photos but, as a precaution I always test a new lens as I’ve had the odd duff one in the past.
Before buying a lens I look at the reviews and forums. For example, Lenstip published some outstanding results for the 16-55mm f2.8 and this was backed up by very positive and convincing comments from many folk, including some of the leading contributors to this forum.
To be specific, whereas Lenstip showed the Brick at 16mm (it’s best FL) & f2.8 to be at least as good as the 35mm f1.4 at f2.8 (both lenses in the centre) my results showed my copy of the Brick had much poorer resolution than that of the 35mm f1.4 at f2.8.
I am aware that I use a different technique to Lenstip to measure resolution and therefore my results do not compare directly to those of Lenstip in an absolute sense but I think they are valid comparatively, i.e. if both lenses had equal resolution, both techniques would show this but the absolute numbers from the two techniques might well differ.
I’d really appreciate your comments on how the resolution of your Brick compares to your other Fuji lenses!
Many thanks
Phil
Many thanks
Phil
